Results 1 to 3 of 3
Thread: Toyota Vitz scratches on screen
    mohsin1230's Avatar
    Apr 2015
    8
    Default Toyota Vitz scratches on screen
    Hi
    i have found some scratches on windscreen i dont know suddenly where it came from, someone told me that it can be removed by cleaning with buffer machine, please suggest me it this buffer process is good ? can i go for that
    thanks
    fouadbakht's Avatar
    May 2006
    3,620
    20
    140 Post(s)
    If the scratches are bothering you while driving, then get them done. If not and are not so deep into the surface, leave them as is. Posting clear pictures will be of great help. Check your wiper rubber. Get the refill if there's the slightest doubt. We suually tend to change these when they really start screeching. For me, it was the part of Stage-! maintenance which included lubricants and filters changing. Rubber has a life too.
    However, I'm also sure to some extent that the culprit might not be the wiper assembly itself. Check the entire windshield for chipping too.
    https://www.facebook.com/hidefcars
    tintin1's Avatar
    Jan 2014
    1,842
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    Quote Originally Posted by mohsin1230 View Post
    Hi
    thanks
    Ignore them and just keep driving.
    Once got scratch on glass, its hard to remove it completely.
    BTW check the wiper rubbers.
    Be Addicted To Help Others.
Tags for this Thread
