Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By tintin1
Thread: Suspension Noise
    shaikhrulez's Avatar
    Dec 2012
    30
    83
    2 Post(s)
    Default Suspension Noise
    I got Vitz 2006, there is sort of squeaking sound coming from front suspension while crossing speed breakers and patches.
    A week ago I got it full serviced with some oiling around its tire and suspension area; for a couple of days sound disappear completely but now again I'm hearing the same noise.
    Please guide me what to do? Is there any part needs to be replaced? I read somewhere that it could be an issue with ball bearing. Is that so?
    StoneCold316's Avatar
    Apr 2011
    224
    3 Post(s)
    Shockers problem or suspension if sound coming on bump free road i had similar prob.. dont repair shockers it would not save your money on long rrun
    tintin1's Avatar
    Jan 2014
    1,848
    8
    61 Post(s)
    2 Thread(s)
    7
    5
    Quote Originally Posted by shaikhrulez View Post
    Seems Shocks got dry.
    Park your car on the plain floor. Insert Key. Turn on the electrical circuit (by 1 key push or 2), but don’t start it.
    Now, move/turn your steering full at right and then left. Do it couple of times and observe if the noise still comes out.
    If yes, then the shocks are dry.
    Open the bonnet.
    You can see the Shock Mountings. If you can open the little rubber lid on them, then its ok. Otherwise drop around 10~20ml mobile oil on its top (in the shock mounting). The oil will slightly go inside the shocks and this noise will go miles away.
    Another method is, visit mechanic and ask him to pull out its both shocks. Make them all wet with mobile oil and then fix again. The problem will be solved.
    But before your drive after re-fixing the shocks, plz have its alignment checked first.
    Be Addicted To Help Others.
    Dec 2012
    30
    83
    2 Post(s)
    Quote Originally Posted by tintin1 View Post
    Open the bonnet.
    Thanks for the detailed reply. I opted for 2nd method went to a reliable mechanic, He took a test drive analyse the condition and then applied some grease in shocks and did oiling around keenchi. The noise has completely gone now Alhamdulillah.
