Results 1 to 7 of 7
Thread: Installing Toyota Yaris Digital Speedometer on Vitz?
    caprice1's Avatar
    Aug 2015
    62
    2 Post(s)
    Default Installing Toyota Yaris Digital Speedometer on Vitz?
    AoA. Guys. Can Toyota Yaris 2nd Gen Digital speedometer work properly on Toyota Vitz 2nd Gen?. The wire grips are same as that of vitz but Yaris has RPM along with temperature display. So wiring is required?
    chinyoti's Avatar
    Sep 2005
    27
    11,952
    5
    107 Post(s)
    5 Thread(s)
    Probably no wiring required. The ecu is similar. Should be pluga and play
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    Uashah007's Avatar
    Mar 2011
    Peshawar
    309
    8 Post(s)
    no brother its not plug and play...
    You will be doing the wiring along with the grips need to be changed..
    Why don't you get analog cluster with RPM. its almost plug and play.
    caprice1's Avatar
    Aug 2015
    62
    2 Post(s)
    I was getting UKDM one in 4.5K. JDM price at least is 8K onwards.
    caprice1's Avatar
    Aug 2015
    62
    2 Post(s)
    Quote Originally Posted by Uashah007 View Post
    Grips are same. I have seen.
    Uashah007's Avatar
    Mar 2011
    Peshawar
    309
    8 Post(s)
    if grips are same,,, still customized wiring will be required, due to difference in the nature of wiring of analog and digital clusters.
    why are you going for digital version. if i am not wrong, digital cluster in Yaris is without RPM.
    caprice1's Avatar
    Aug 2015
    62
    2 Post(s)
    UKDM one have RPM like in Vitz First Gen Digital Speedometers.
