Results 1 to 3 of 3
Thread: VSC & ECT vitz
    sd
    sd is offline
    sd's Avatar
    Sep 2005
    25
    1,400
    3 Post(s)
    Default VSC & ECT vitz
    whts the difference between VSC & super ECT vitz. & when do we use D2 & L in automatic transmisson.
    Why drink and drive when you can smoke and fly?
    >>>>D£Ŧƛᵯƛ§Ø ƁØ¥§<<<<
    Deloy's Avatar
    Apr 2006
    41
    203
    VSC stands for vehicle stability control, which automatically adjusts the power at each wheel to prevent skidding or wheelspin so that the car will corner in the safest and most stable way. It is not present in Vitz (yaris) as far as my knowledge is concerned.
    Super ECT is the auto transmission in Vitz (ECT: Electronic Control Transmission).This transmission, claimed to be highly efficient, has adaptive programming and improved driveability on hilly roads with a reduced number of gear changes. As for D2, in this mode the gear will not shift to 3rd, used if you want to climb or accelerate very quickly. L is low gear, in which it will not shift to 2nd and used for towing or extremely upslope or downslope driving
    Deloy
    sd
    sd is offline
    sd's Avatar
    Sep 2005
    25
    1,400
    3 Post(s)
    thnkz buddy.
    >>>>D£Ŧƛᵯƛ§Ø ƁØ¥§<<<<
