Results 1 to 7 of 7
Thread: Vitz Knocking sound.
    hassansanawan's Avatar
    Jan 2014
    Multan
    32
    12
    Default Vitz Knocking sound.
    I have tried several Fuel Stations but could not resolve the problem of Knocking in Vitz 2001. Sometimes its less nd sometimes it even knocks in the 2nd gear. But it only knocks with AC. If the AC is switched off it wont knock. Somebody said that I should use Mix fuels. Can somebody help me on that??
    electrolics's Avatar
    Jun 2012
    Daharki
    46
    8 Post(s)
    does it knock on hi-octane?
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Mileage?
    Jan 2014
    Multan
    32
    12
    Hav'nt tried on Hi-octane.. What should be the ratio??
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Mileage
    sirdneo's Avatar
    May 2013
    84
    4 Post(s)
    Quote Originally Posted by hassansanawan View Post
    Vitz tank capicity is around 40 Ltrs, so first fill 500 Rs (aprox 6 Liters of High Octane) and fill remaining tank with normal (It would be around 35 Liter Normal and 5 Liter High Octane).
    It should remove your knocking issue, also reset your ECU as well by removing battery terminal for around 10~15 mins. So computer can adjust itself according to new fuel.
    Jan 2014
    Multan
    32
    12
    Thats great help..
