Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By rajaatta
Thread: Toyota Vitz Transmission Problem
    nadirmengal's Avatar
    Mar 2008
    Quetta
    31
    Default Toyota Vitz Transmission Problem
    I have a 2005 model Vitz, old shape, engine type 1SZ-FE. When the car is in drive "D" suddenly it starts changing to "2" and then back to "D", and to "2" then to "D" again (just like flashing), does this for a few seconds and stays at "D" afterwards. Showed it to a mechanic, he said that the gear oil is too thin and low, needs changing.
    Question is, whether the mechanic is right? If yes, which gear oil to use, how much to use and is the old shape Vitz CVT or ATF?
    BY old shape I mean the model before 2005.
    Quick replies please
    UmarAzam's Avatar
    Mar 2007
    27
    520
    5 Post(s)
    ATF to be used in Vitz 2004. Vitz in 2005 (New shape) has cvt transmission.
    Eat my dust
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Use original Toyota ATF comes in 1 liter tin pack black
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Get the Gear shifter cable adjusted it get loosed in those old trans. Your problem would be solved dont mess with the viscosity of ATF. Or you will end up in a dead street by transmission failure due to CL pouring in the atm.
