Results 1 to 4 of 4
Thread: rear light broken plus acceleration
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    Default rear light broken plus acceleration
    i have 2006 vitz 1.3, have following issues need experts to throw some opinions
    1. was going to peshawar when a biker hit at rear light, which broke light, its working fine, but a part of plastic is gone. is there a place to find cover or i will hve to buy new light. i have checked chah sultan..did not fin any
    2. i was coming for peshawar, with 4 persons sitting, acceleration was low, car was not reaching at least 100 km speed. have not experienced it before.
    thanks
    oiqbal's Avatar
    May 2014
    33
    37
    1. Get a new light
    2. Get your car tuned up. Engine plugs, air filter, sensors, injectors cleaned. If the problem persists you'd need to get your catalytic converters checked and if they're choked ideally get them replaced and Pakistani style get rid of them.
    Hope this helps
    oiqbal's Avatar
    May 2014
    33
    37
    FYI start using HOBC in your car. It'll justify the cost since you'll get an extra km or 2 on each litre. Acceleration will be smooth and vibration will reduce. Plus engine tuneups will last longer and hence the engine will last longer. The Pakistani regular fuel is crap.
    oiqbal's Avatar
    May 2014
    33
    37
    And observe the difference after atleast 3 complete tanks of HOBC.
