Results 1 to 10 of 10
Thread: Toyota Vitz Engine Turns Off While Driving
    informtausif's Avatar
    May 2011
    7
    Question Toyota Vitz Engine Turns Off While Driving
    Hello,
    I own a Toyota Vitz 2006. I'm facing a problem for last 3 days. After running around 10KMs, my car give jerks and some times the engine gets turned off. I have to give it 2, 3 tries to switch on again.
    What could be the potential problem?
    dayrider's Avatar
    Mar 2006
    27
    1,895
    5
    16 Post(s)
    2 Thread(s)
    Quote Originally Posted by informtausif View Post
    Hello,
    A new fuel filter
    oiqbal's Avatar
    May 2014
    33
    37
    Does the car vibrate prior to shutting down. This could be because of poor/bad quality fuel. Try to get your fuel tank filled with Hi Octane if it doesn't resolve the issue then a complete engine tune up along with cleaning of sensors from a good mechanic should help. Hope this helps.
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    What odo readind? Any check light when problem occurs?
    humayun.chughtai.7's Avatar
    Nov 2013
    Multan
    20
    620
    9 Post(s)
    seems like any electrical problem !
    mhaderaziz_official's Avatar
    Feb 2014
    15
    1,423
    31 Post(s)
    Have the car scanned for any error codes.
    The hardest part about moving forward is not looking back.
    May 2011
    7
    Quote Originally Posted by oiqbal View Post
    Yes car vibrates prior to shutting down.
    May 2011
    7
    Quote Originally Posted by akramsalman.164 View Post
    I have the car scanned and there is no error code
    May 2011
    7
    Quote Originally Posted by humayun.chughtai.7 View Post
    I have scanned the car and there is no electrical error
    oiqbal's Avatar
    May 2014
    33
    37
    Get plugs, sensors and injectors cleaned. Use hi octane for atleast the next two or three tanks and then observe. I've faced the issue and it was resolved by following the steps. Good luck.
Tags for this Thread
