Can anyone describe the correct procedure of Changing Transmission Oil of Vitz 2009 1.0L CVT. I have noted few points from other transmission oil change PW threads but didn't find correct procedure of changing CVT Oil. Below are point mentioned. I hope it will help other members. If any of these points are incorrect please let me know so i will correct it accordingly.
1- CVT Oil Part No.: 08886-02105 (4L Sliver Tin Box)
2- CVT Oil drain temperature is 36 C to 46 C
3- Whenever Replace Transmission oil clean/replace oil filter too if required
4- CVT Oil Filler Port Bolt that marked as TC
5- Oil Capacity: 6.30 ltrs (This is capacity i have read in manual. Some ppl. reported transmission Oil drain/refill around 3.5 - 4 ltrs)
6- CVT Oil press calibration (This can check pressure for CVT fluid. I don't know is it required to do after every Transmission Oil change)
Note: Use this information at your own risk because i have read this information on forums instead of manual. So Authenticity of information can not be guaranteed.
