Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By rajaatta
Thread: Overhaul or engine swap
    Alpina's Avatar
    Jun 2010
    Chiniot
    27
    16
    Default Overhaul or engine swap
    Salaam, I have a 2006 model Vitz. It is 135k km driven. I have noticed that the engine acceleration has reduced plus the engine sound is louder than before.
    When I turn the engine off, there is a smell of something burning.
    Mobil oil levels are fine. Mileage is not affected.
    Knocking is a disease common to this generation Vitz (it is present)
    What should I do?
    hash4u's Avatar
    May 2005
    38
    24,363
    18
    404 Post(s)
    13 Thread(s)
    13
    catalytic converter is chocked
    get it cleaned
    rajaatta's Avatar
    Apr 2014
    680
    12
    25 Post(s)
    Quote Originally Posted by Alpina View Post
    What should I do?
    the problems you had mentioned does indicate the CAT Blockage and plus some different more scenarios if the engine is weak just get it Overhauled along with transmission Valve Body assy service. with all lubes changed and you will be good to go.
    Alpina's Avatar
    Jun 2010
    Chiniot
    27
    16
    Quote Originally Posted by rajaatta View Post
    CAT is the catalytic converter? If yes then it is removed most likely. Overhauling from where exactly? And how much will it cost? I am in Lahore
    hash4u's Avatar
    May 2005
    38
    24,363
    18
    404 Post(s)
    13 Thread(s)
    13
    if the car is driving heavy,
    sound increased
    top speed killed
    sure shot cat converter blocked
    reconfirm before touching the engine
    Alpina's Avatar
    Jun 2010
    Chiniot
    27
    16
    Ok, any suggestions for good mechanics?
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,578
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Obama Car Care centre Garden town lahore 0321 4106898 can give you money worth satisfaction for vehicle repair
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    Alpina's Avatar
    Jun 2010
    Chiniot
    27
    16
    Madina autos, jail road?
    Alpina's Avatar
    Jun 2010
    Chiniot
    27
    16
    What about madina autos? I heard they are expert in Japanese vehicles
    saad_lucidlabs's Avatar
    Jul 2013
    Default 2SZ Engine Overhaul in Islamabad
    Aoa,
    Guys I recently bought a 1.3L 2006 Vitz. There is bluish grey smoke in the exhaust at higher RPMs.
    Solutions that come to mind:
    1. Get engine overhauled.
    2. Buy a new (kabli) engine/engine block
    I am inclined to getting the 2SZ engine overhauled but the issue is that there are no spare parts available.
    Further Complication:
    The mechanic I am getting this done from says,
    'once the engine needs overhauling, the bore-diameters of the body that houses the pistons; are stretched due to wear and tear, this means that the standard parts that are present do not work in the overhaul and bigger size parts are required.'
    These bigger size parts are nowhere to be found!
    Any brother who has gotten a successful overhaul done of a 2SZ engine is more than welcome to show me the way!
    Thanks to all.
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by saad_lucidlabs View Post
    Aoa,
    Thanks to all.
    Odo reading?
  12. #12
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    Aoa,
    Thanks to all.
    1st Thing 1st....Did You Compression Test It Before Claiming Rings Pistons Weak? Smoke Can Also Be Due To Valve Seals Or Other Factors....
    Proper Inspection Can Clarify Either It Need Standard Or Oversized Ring Pistons And How Much Over-Sized....And That Is Only Possible After Opening Engine
    DId You Check Market For 2SZ Parts Availability....You Gotta Do Alot Of Homework Before Taking Decision....!
    Keep In Mind That Geting Kabli Engine Block Is Also A Risk..You Never Know How Much Km's Its Driven Before Cut To YARD....But The Last Resort If Parts Can't Be Sourced....Nowadays People Can Source Parts Outside PK And Get It Done...
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
  13. #13
    Jul 2013
    Odo reading = 230k km
  14. #14
    Jul 2013
    Compression Test, lol.
    Ustaad g just pressed the accelerator few times until there was blue smoke!
    Where are compression tests done in Pindi/Islamabad?
    Please guide me to the place where in your opinion they properly inspect the car.
  15. #15
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    Check pcv and breather and contact rozzzz in isb for compression test
  16. #16
    rajaatta's Avatar
    Apr 2014
    680
    12
    25 Post(s)
    Get in contact with rehman autos they will help you resolve your issue
  17. #17
    anc
    anc is offline
    anc's Avatar
    Mar 2007
    Rawalpindi
    1,051
    38 Post(s)
    Rehman Autos on IJP road just before the double road Ishara.
