Page 3 of 3 FirstFirst 123
Results 41 to 44 of 44
Like Tree24Likes
Thread: My recommendation for Oil in vitz
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    Default My recommendation for Oil in vitz
    AoA,
    I had waited for 2 months to see how does Valvoline perform, i was using zic. After positive reviews from my friends, i got it changed this friday.
    Results: 200% dam positive
    I saw my engine running very very smoothly, 200% soundless with excellent improved milleage.
    i would highly recommend it to all guys, i am using it , any one else used it please share your reviews.
  2. #41
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Quote Originally Posted by zohaib1431 View Post
    Zulfiqar bhai i want to add one more thing....I went for full radiator service in workshop after that day that problems appeared in my automatic transmission.....So that could be the reason????
    plz check the ATF Fluid level first may be the ATF is drained and you are facing the problem's . Check for the color of the atf if it is RED, Brown or same like color then its fine and also check for the Radiator coolant. Check for the mixing of any kind of oil in it may be the Cooler is leaked. Look for the coolant level is it decreasing or not .
  3. #42
    zohaib1431's Avatar
    Dec 2015
    24
    The Atf fluid level is in high side....the color of Atf is dark brown and the coolent level is not decreasing
  4. #43
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    how much overfilled
    overfilled ATF can foam up and cause slipping issues also as foam/bubbles are useless for hydraulics, it is critical to have exactly correct amount of ATF in the unit. Also make sure there is no trace of coolant/water in the ATF, and if its darkened to a black/brown colour then you are waaaaaaay overdue for change. Its supposed to look like rooh afza sharbat, your trans takes regular dexron type ATF - type IID or III.
    It has short service life and when discoloured, it is supposed to be changed out.
  5. #44
    zohaib1431's Avatar
    Dec 2015
    24
    how much overfilled
    Mechanics told me that you need to change a gearbox or one mechanic told me that ur car need to change a clutch plates....
    What can i do??? I m very much confused......After the radiator service it happened
  6. 28-03-2016, 04:55 AM
    Newbie
