Results 1 to 15 of 15
Like Tree6Likes
  • 1 Post By sohelahmed
  • 2 Post By doc.tarzan
  • 1 Post By devils_smile
  • 2 Post By FaatehRehman
Thread: is it possible to make vitz cabin noise free to max extent
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    Default is it possible to make vitz cabin noise free to max extent
    even if you hvae everything perfect, there is still a bit of engine and outside noise, is there some technology to reduce noise in cabin to max extent....
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Quote Originally Posted by sohelahmed View Post
    Yes There is a technology called AKA ( Sell Your Vehicle and Buy A NEW ONE). What kind of noises you want to eliminate in it if its already in perfect shape. there is no sound jumps in the cabin if the every thing is working perfect. Vitz is a very smooth vehicle in terms of noise on long and semi long routes. no Noise came inside the cabin at all.
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    i know, but road noise, engine rpm noise is still there inside, i have checked many vitz, its not even 90% noise free i believe...
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    May be you had driven the unfit vehicles. Tyres and incorrect oil viscosity end up in louder noises by these kr series engines
    MADDYBOY's Avatar
    Jun 2006
    1,069
    16 Post(s)
    he is right vitz has noise in the cabin
    ali15144's Avatar
    Nov 2014
    400
    4 Post(s)
    There is already a topic present where a guy makes his vitz sound free by using sound deadning sheets.... Search for it
    doc.tarzan's Avatar
    Dec 2009
    Mardan
    34
    2,550
    47 Post(s)
    4 Thread(s)
    vitz is noisy as hell and i hate the engine noise of vitz. it sounds as if you are perpetually going uphill and the car is struggling
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    can you share the link please, i have searched there lots of threads, but on different issues with car like cat removal noise, kar kar noise ...in my case i am talking about a normal cabin noise which is quite a bit...
    devils_smile's Avatar
    Feb 2009
    Bonn
    26
    4,584
    171 Post(s)
    6 Thread(s)
    There is no doubt that there is minimal insulation in the xp90. Its so bad, I though I was driving a scooter the day I bought the car. If you really want to eliminate foreign noises inside the cabin, you will have to spend at least 50k. To make the cabin as quite as possible, you need to do three layers of sound insulation/deadening.
    1) Sound Deadening Sheets to reduce rattles and body flexing. This prevents any squeaks and metal resonance. This is a link to my vitz where I did all the doors, trunk, a,b,c pillars and front firewall. I also did parts of the floor.
    https://www.pakwheels.com/forums/car...-3#post4855279
    2) Mass Loaded Vinyl. This is sound barrier. It prevents sound entering the cabin. Use these on the floor, trunk, firewall and wheel arches. You can use them on the inner sheet of the doors too. Here is picture of a mlv applied to a G-class wagon. I've bought the sheets for my vitz but havn't yet got the time to put them on.
    is it possible to make vitz cabin noise free to max extent -1649233
    3) Closed Cell Foam. These act as sound absorbers by muffling the sound. Most people in pakistan use Jumbolon since CCF is kinda hard to find here. Jumbolon works great aswell. It may not be a CCF to be exact but it works in a similar fashion.
    The three of these combined will do wonders to the cabin noise levels.
    My 1985 Mercedes Benz W201 190D (DIY's, Detailing and Photo-shoots)
    http://www.pakwheels.com/forums/members-member-rides/207432-my-mercedes-c-class-w201
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    thank you, i am afriad, i can not do it my self, neither find any person who is reliable. can you recommend a person who can do all this procedure. thanks,
    Quote Originally Posted by devils_smile View Post
    anc
    anc is offline
    anc's Avatar
    Mar 2007
    Rawalpindi
    1,053
    38 Post(s)
    Brother where did you buy the mlv from and kindly also share price?
  12. #12
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Bro there is alot of noise from back of the vitz as well as it doesnt have a rear parcel tray !
    When i installed a parcel tray in the back of my vitz the road and tire noise was reduced noticably !
    Sent from my iPod touch using PW Forums
  13. #13
    FaatehRehman's Avatar
    Apr 2010
    Rawalpindi
    25
    222
    The best way I found to combat the noise is to turn up the stereo a bit
  14. #14
    usama1's Avatar
    Sep 2005
    37
    1,463
    Quote Originally Posted by doc.tarzan View Post
    Exactly...whatever the model is...its a worst car in terms of disturbing engine noise...
  15. #15
    haroon.virk's Avatar
    Sep 2014
    Tobatek singh
    350
    9 Post(s)
    So we have to use all the three options combined to make noise free cabin.
    Can you tell us where to find/buy these things and in how much quantity:
    1. Sound Deadening Sheets?
    2. Mass Loaded Vinyl?
    3. Closed Cell Foam or Jumbolon?
    Also post a picture of these three items, it would be very helpful for everyone.
