Results 1 to 7 of 7
Thread: vitz engine roughness and vibrations
    shahbaz5's Avatar
    Oct 2010
    7
    Default vitz engine roughness and vibrations
    Aoa all
    I have vitz 2011 1.0. I have purchased it. On idle in parking, Drive or NEUTRAL, its engine feels like rough running and makes the complete car vibrate. Goes away once car accelerates. Will engine tuning and may b spark plugs change solve the problem???
    I am planning on getting the engine tunning done and throttle body serviced alongwith spark plugs change if req.....comments of vitz users are requested on this. Also what knd of spark plugs are recommended for vitz of this model....????
    umarsaleem143's Avatar
    May 2015
    16
    AOA - i have forgot to turn off the parking lights resulted the battery to lost all the power. when i found it this evening.
    i got my car jumped start , which went easily.however now when i put my car on N and getting slow on D on any signal and stuff the engine starts vibrating resulting the whole car to be throbbing. however asap i press a little accelerator pedal, the vibration stops. also there is no vibration while i m driving. the problem occurs only when i stop my car with engine stars. kindly assist. thanks you
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by umarsaleem143 View Post
    Most probably your ecu restarted and forgot clutch calibration
    May 2015
    16
    Thanx saboor
    May 2015
    16
    How do i fix it
    May 2015
    16
    Also guide best workshop in lahore
    May 2015
    16
    Is it possibe in cvt
