Results 1 to 6 of 6
Thread: Engine vibrate at idle
    umarsaleem143's Avatar
    May 2015
    16
    Default Engine vibrate at idle
    AOA - This morning i have forgot to turn off the parking lights resulted the battery to lost all the power. when i found it this evening.
    i got my car jumped start , which went easily.however now when i put my car on N and getting slow on D on any signal and stuff the engine starts vibrating resulting the whole car to be throbbing. however asap i press a little accelerator pedal, the vibration stops. also there is no vibration while i m driving. the problem occurs only when i stop my car with engine stars. kindly assist. thanks you
    razaahmed225's Avatar
    May 2011
    Rawalpindi
    130
    9 Post(s)
    Quote Originally Posted by umarsaleem143 View Post
    Hi umer i am not an expert but had a corolla 2003 it had same kinda problem. I went to toyata gt motors to solve the problem. They cleaned the throttle body and replaced some of its part. Running smooth since then...... better to check ur throttle body..... but the battery issue can also lead to some computer fault. U must should inspect ur car by a obd sensor
    May 2015
    16
    Thnx
    And what about clutch calibiration
    Some told me about it
    May 2011
    Rawalpindi
    130
    9 Post(s)
    Thnx
    U have a vitz right..... they are mostly automatic...
    If it is a manual then check ur pressure plate.. beacuse as u said it is giving u problems when ur car is at idle position..
    zeecom's Avatar
    May 2008
    32
    63
    Its just ECU reset, should be ok with a few runs. I faced the same problem a week ago after battery replacement, tried Idle Learn Procedure from a forum post here and it worked for me
    May 2015
    16
