Results 1 to 16 of 16
Like Tree2Likes
  • 1 Post By wasihasan
  • 1 Post By newtechautos1
Thread: Engine vibrate at idle vitz 2012
    umarsaleem143's Avatar
    May 2015
    16
    Default Engine vibrate at idle vitz 2012
    AOA i have forgot to turn off the parking lights resulted the battery to lost all the power. when i found it this evening.
    i got my car jumped start , which went easily.however now when i put my car on N and getting slow on D on any signal and stuff the engine starts vibrating resulting the whole car to be throbbing. however asap i press a little accelerator pedal, the vibration stops. also there is no vibration while i m driving. the problem occurs only when i stop my car with engine stars. kindly assist. thanks you
    hash4u's Avatar
    May 2005
    38
    24,363
    18
    404 Post(s)
    13 Thread(s)
    13
    disconnect the battery for few minutes and re connect (if battery is not weak),,,should be fixed
    shah_rukh1992's Avatar
    Mar 2015
    24
    46
    2 Post(s)
    Rpm issue?
    Nabeel_Ali's Avatar
    Feb 2010
    24
    3,509
    108 Post(s)
    Quote Originally Posted by umarsaleem143 View Post
    Get your throttle body and air filters cleaned. It will be fine
    Sent from my SM-N920C using Tapatalk
    KhurrumIftikhar1's Avatar
    Feb 2011
    Gujrat
    22
    253
    4 Post(s)
    If your car is working fine before then change the battery or get it charged from some batterry shop
    Then after putting new battery start your car and let it iddle for 5 min (do not push throttle) then turn on the headlights let the car iddle again for 3-4 min with headlights on
    Then turn on the ac and let car idle for 3min
    Then turn off the ac and let car iddle for 2 min
    wasihasan's Avatar
    Mar 2015
    14
    11
    Get your engine tuned (throttle body) (starter body) (spark plugs) & etc..... Get your air filter cleaned. I.A car will stop vibrating. And yes Electronic tuning and check...
    chsalmansarwar's Avatar
    Dec 2012
    5
    Aoa. Fellows i have toyota yaris 1.4 D4D turbo diesel 2004 model. Can anyone tell me from where to tune it up in rwp/islamabad bcoz i havent bought a diesel car before hence no idea in this regard
    rajaatta's Avatar
    Apr 2014
    680
    12
    25 Post(s)
    Quote Originally Posted by chsalmansarwar View Post
    Go to Rehman Auto's for special diesel Tuneup.
  9. 23-03-2016, 12:24 AM
    Site Banned
    Reason
    spam
  10. #9
    civic_90's Avatar
    Nov 2006
    30
    764
    3 Post(s)
    Quote Originally Posted by newtechautos1 View Post
    Do it in a way like take a carburator cleaner of medium size of any good brand (i m using carlong 360 degree brand) and feed your car with it through throttle while pressing acc. Pedal about 4000 to 4500 rpm. Put it completely. Afterwards remove throttle (dont forget to dc negative terminal of battery) clean it with petrol or same carb. Cleaner. take your spark plugs out as well and clean them also with same carb spray as they ll become black due to fuel excess due to carb spray. Install these parts back. Reconnect your battery and with any good technician calibrate your g sensor when done this process. This ll surely help you out.
    he is talking about a D4D Diesel engine and you are asking him to clean the throttle and spark plugs
    For Mechanical Works and Car Detailing, Contact 0333-3738698
  11. 23-03-2016, 01:21 AM
    Site Banned
    Reason
    spam
  12. #10
    civic_90's Avatar
    Nov 2006
    30
    764
    3 Post(s)
    My answer is for umersaleem143 dear as he raised this here
    ohh right. my mistake............
  13. #11
    rajaatta's Avatar
    Apr 2014
    680
    12
    25 Post(s)
    Are you serious????? Injecting the Carb Cleaner will burst this diesel engine into pieces and it all starts with hard rattling sound and few seconds later KAABoooooM. All of the piston connector rods will bent away like a mesh stick..... or possibility is the cylinder will be blast out....... never use carb cleaner in diesel engines..... update your knowledge.... have peace
  14. #12
    civic_90's Avatar
    Nov 2006
    30
    764
    3 Post(s)
    Quote Originally Posted by rajaatta View Post
    The original post is about petrol engine. This random giy bumped in with his diesel engine querry.
    I thought the same lol.
  15. 23-03-2016, 06:23 PM
    Site Banned
    Reason
    spam
  16. #13
    rajaatta's Avatar
    Apr 2014
    680
    12
    25 Post(s)
    I guess you seem so much excited to post something. I have clarify already my dear what i was meant about and what i gave solution for. My answer was originally for the post who raised the question initially not for that diesel guy.
    BTW the scene was so dramatic . Rajaatta
    Best of luck always do mention the post or reply with quote. To pinpoint the actual post you are replying to. New Tech Auto. As you are a new member plz in future do so like I mentioned. And welcome to the pakwheel family.
  17. #14
    rajaatta's Avatar
    Apr 2014
    680
    12
    25 Post(s)
    Quote Originally Posted by civic_90 View Post
    This is a public forum and any member can ask about the problems they are facing and can ask the question in any ongoing forum chat we cant stop them so. Keep helping other peaople this will help you in your learning process.
  18. #15
    civic_90's Avatar
    Nov 2006
    30
    764
    3 Post(s)
    I mever denied to help. Have worked in toyota 5s dealership for aboit 2.5 years so yeah I am always ready to help
  19. #16
    rajaatta's Avatar
    Apr 2014
    680
    12
    25 Post(s)
    Ok its good to hear but on which designation in toyota dealership. What is your specific speciality? Mechanical, Electrical, Systematic Diagnostic, Pre mature Diagnostic, Central init Diagnostic, or Body Repair section.
