Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Like Tree13Likes
Thread: How to tow another car using vitz ?
    goldenstripes's Avatar
    Oct 2014
    31
    49
    2 Post(s)
    Default How to tow another car using vitz ?
    Hey guys
    So i know there is the removable plastic panel in front where we screw / twist on the bolt thing when we need to get the vitz towed
    But haven't found any similar arrangement at rear end for when j want to tow another car...
    Perhaps some one who has towed another car using vitz can guide me here
    Also the safe towing load for vitz is 600 kg. how much does an avg car (alto, corolla or city) weigh ? Any ideas ?
    Thanks in advance
    memad's Avatar
    Nov 2010
    39
    5,504
    180 Post(s)
    If there is no such arrangement ar rear it means that the car is not ment for towing.
    Get a proper truck application for the requires job.
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Quote Originally Posted by goldenstripes View Post
    Hey guys
    Thanks in advance
    First of all it os not recommended to tow the vehicle with little cvt vitz. But incase you need to tow some corolla or any other vitz you can tow it easily. Just shift into B Gear Mode and drive steady at 30 km/h dont floor the pedal to the metal. Every 50 kms make some stops for 10 minutes and keep the engine running it will allow the cvtf fluid to cool down and then you can tow the vehicle for another 50 km's.
    memad's Avatar
    Nov 2010
    39
    5,504
    180 Post(s)
    Quote Originally Posted by rajaatta View Post
    He first wants to know where to hook the vehicle to be towed at the back of vitz?
    Oct 2014
    31
    49
    2 Post(s)
    @memad
    Yep wanted to know where to pass the ropes so i dont put rope in some other assembly and damage the car ...
    @rajata
    Vitz is 1000 cc japanese car... I have towed a civic on pakistan made suzuki alto... Surely vitz can handle it too dont you think ?
    ZainMahdi's Avatar
    Dec 2012
    22
    928
    50 Post(s)
    @memad
    @rajata
    You can also redline your car after starting it on a December morning. Just because it keeps working doesn't mean it is in perfect condition.
    Towing without an aux cooler on an auto/CVT four banger shouldn't be done unless you want to rebuild/replace the tranny frequently.
    _ 22 km/l from '03 VTi automatic, with plenty of room for improvement
    _ How to hypermile: http://www.cleanmpg.com/community/index.php?threads/1510/
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    @memad
    @rajata
    F10 a have better lower end torque than 1krfe and CVT make situation worse for vitz
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Quote Originally Posted by memad View Post
    Open the trunk lid and get it tied with the neck of the driver who is curious to tow the vehicle..................
    Now putting this joke aside
    For temporary towing get the ropes tied to the rear end main low drive bar and many more places where a rope can easily be tied. But remember More frequent Jerks and the whole low end will end up on road while you will be moving on road with 2 front wheels. ........
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Quote Originally Posted by saboor73 View Post
    F10 and f8 had slight low ratio transmissions on them. The 1kr is much better than those but the cvt transmission should be healthy. If some one tows the vehicle on D drive then he will ends up in broken secondary cvt belt assy along with start clutches to be cooked like a roast....... so for towing always use B gear Mode it will ensure that transmission will not change the ratios and stays in lower ratios ensuring best power output.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by ZainMahdi View Post
    MAN - you guys are spoiling the fun!!!
    this person thinks his "japani vitz" is a stump puller - I was planning to wait with a bag of popcorn to hear about "meri gaari ka gheyr kaam nahi kar raha"
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Pr meri gari ka gear goun goun kar raha hai par na agay jata hai aur na peechay ab kya karoon.................
    Acha hota ke rasiii mein apnay galay mein daaal leta vitz say tow na karta......
  12. #12
    memad's Avatar
    Nov 2010
    39
    5,504
    180 Post(s)
    I have seen this type of assembly on some cars, mount it there and you are good to go. May be the bumper has to be cut open to make room for the hook but the setup surely looks sturdy and can tow a big load too.
  13. #13
    Oct 2014
    31
    49
    2 Post(s)
    @Xulfiqar - your heartfelt concern for a pak wheeler spoiling his vehicle so u can have a hearty laugh id really touching
    I thank you from the bottom of my heart
  14. #14
    Oct 2014
    31
    49
    2 Post(s)
    @memad
    Thanks but i get the point of avoiding towing another vehicle with my "Japanese stump puller" till absolutely essential and then too over small distance/ short time.
  15. #15
    aijazkhalid's Avatar
    Dec 2012
    25
    22
    3 Post(s)
    @memad those tows usually come with the car or else the socket where the tow tool is attached can already be seen since its attached to the chassis, they are normally only seen on jeeps, mini vans and US and European cars and you are told by the dealers that you can tow with the vehicle or not and how much weight you can tow with it if you just go and ask them. According to the vitz user manual(which is open in front of me) they recommend that you do not tow any thing with it so rather then using the vitz get a different loaner from your family and friends and use that to tow the car.
  16. #16
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    This is not meant to tow a car, this is meant to pull a small trailer and there are certain precautions when you tow a vehicle, the towing vehicle should be heavier than the vehicle in tow otherwise you get into a situation where the trailer wags the tractor and you end up upside down on the road.
    Your vitz has no towing hooks - the little eye toyota provide is to pull the car onto a trailer bed and tie it down with that too. Using a rope on the rear suspension linkages etc is a 100% guarantee to bend them out of shape.
    Its basic common sense that you dont tow a vehicle without proper safety checks and procedure (check your owner's manual - OH, its a JDM its either lost, missing or in japanese)
  17. #17
    edrahool's Avatar
    Feb 2008
    Rawalpindi
    32
    466
    15 Post(s)
    Surprise to know that vits do not have that towing arrangement at back..
    My passo (2010) has that in both front and back with Japanese hook cam with it.
    Its has sam engine as vits and same cvt gear.
  18. #18
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by edrahool View Post
    CVT on passo and Vitz is different
  19. #19
    edrahool's Avatar
    Feb 2008
    Rawalpindi
    32
    466
    15 Post(s)
    Oh i didn't know that.
    Whats the difference in both?
  20. #20
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Drive ratio
    Dip stick (vitz doesnt have dipstick)
