Results 1 to 3 of 3
Thread: Vitz 1.3L 2SZ-FE engine overhauling
    saad_lucidlabs's Avatar
    Jul 2013
    Default Vitz 1.3L 2SZ-FE engine overhauling
    Aoa,
    Guys I recently bought a 1.3L 2006 Vitz. There is bluish grey smoke in the exhaust at higher RPMs (just before acceleration cut-off point)
    Solutions that come to mind:
    1. Get engine overhauled.
    2. Buy a new (kabli) engine/engine block
    I am inclined to getting the 2SZ-FE engine overhauled but the issue is that there are no spare parts available.
    Further Complication:
    The mechanic I am getting this done from says,
    'once the engine needs overhauling, the bore-diameters of the body that houses the pistons; are stretched due to wear and tear, this means that the standard parts that are easily present from local spare part vendors do not work in the overhaul project and bigger sized parts are required.'
    These bigger size parts are nowhere to be found!
    Any brother who has gotten a successful overhaul done of a 2SZ engine is more than welcome to show me the way!
    I line in Pindi/Islamabad and have asked around spare parts shops that are very famous in saddar (Ejaz Autos/Idrees Autos/Mehran Autos etc)
    Thanks
    ab6666's Avatar
    Nov 2013
    N/A
    332
    4 Post(s)
    Quote Originally Posted by saad_lucidlabs View Post
    Aoa,
    Thanks
    valve seals are worn... changed them and u r good to go.
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Aoa,
    Thanks
    Visit Rehman Autos on IJP road they will help you resolve your problem...
Tags for this Thread
