Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By rajaatta
Thread: ac issue help after replacing pipes
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    Default ac issue help after replacing pipes
    aoa guys, i have vitz 06, 1.3
    its ac is super awesome until last september when due to hot whether one of the ac pipes got leaked, i went to good mechanic, he replaced the pipe, refilled gas and everything perfect, previously the ac was so chilling that with fully loaded cabin, i would need to turn off occasionaly due to extreme cold in july august, i used to limit it to 1.
    after replacing the pipe and refill the situation has changed, its not the same chilling any more, i checked following twice,
    1. gas
    2. condensor, washed, cleaned
    3. heat and cold knob and its wire under steering controls
    4. thermostate is perfect
    everything is perfect but the cooling is now reduced to 80 % and even on 3, it does not cool that much. the mech said everything is ok, what can be the issue, the cooling pipes under hood are chilling, but inside its not.
    what can be the issue.
    thanks,
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Quote Originally Posted by sohelahmed View Post
    1. gas
    thanks,
    Welcome back. Straight away check the gas quality its not fine and its also overfilled....
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    ata bhai, how can i check quality of gas, can you help , also do i have to refill it again, it was filled by abu bakar , he is famous for ac related stuff...
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Dont know abubakr but straight away check the cooling evaporator inside the dash board may be its fins are dirty due to bad cabin filter. And also hook up an temperature sensor to detect on how much temp the compressor cutts offf..... may be the A/C cutts off to soon
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    ok thanks, should i bring it to you, can you check it or sould i go to abu bakar
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    ok now i have went to lots of ac mechanics to check what they suggest, mostly in rawalpindi, eartern car ac, western car cool and many others, this is what most of them say
    in the day time, high flow pressure reaches to 40 or above due to which cooling becomes low and in the evening this pressures comes below and cooling gets better. They say the high flow pressure should be at 20 in day time as well. and yes in evenings cooling is great and in morning its nominal cold air. They are suggesting full service of ac system costing around 5500.
    i had replaced filter under dashboard as well.
    any expert opinion please.
    thanks,
    imrananr's Avatar
    Jun 2014
    845
    5
    19 Post(s)
    thanks,
    Gas pressure needs to be checked using recommended instruments, also system to be checked for any leakages.
    Don't leave a highway for a byway....
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    chcked from dozens of ac mechas, well know and common,
    hassantahir2's Avatar
    Mar 2016
    Faisalabad
    22
    813
    17 Post(s)
    Have you checked the expansion valve.! If vitz have any....
    Sent from my D2502 using PW Forums mobile app
    Four wheels move the body
    Two wheels move the soul
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    everything fine now, just got my car serviced three times within a week,
    alee1's Avatar
    Oct 2009
    Wah cantt
    27
    1,998
    12 Post(s)
    GA ACF | Robur
    a friend of mine works in HVAC thingy and they do this robur installations ... and i have a company of mine related to solar , generators and general order supply related and when suggesting client solar or genset we do payback calculations and roi in depth...
    the electricity consumption and cooling capacity is mentioned in the link. i hope i have answered your question well
    mAin tE h0nDa hE lAisAn...
  12. #12
    tintin1's Avatar
    Jan 2014
    1,842
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    Quote Originally Posted by rajaatta View Post
    Yes exactly. The quality of the gas is not original.
    The summer season is highest peak season for AC technicians to make money. And most easy way is, fill low grade quality gas in the AC. And hence customer keep coming back to them and slowly they start attacking their pockets.
    If everything is OK in your car system, then it seems fill gas quality is not upto mark.
    you should better go at some reputed AC shop and get it re-filled with recommended gas only.
    There will be sticker on your car (on at near to radiator) where company had advised the recommended gas for AC. Check it and fill the same.
    Be Addicted To Help Others.
