aoa guys, i have vitz 06, 1.3
its ac is super awesome until last september when due to hot whether one of the ac pipes got leaked, i went to good mechanic, he replaced the pipe, refilled gas and everything perfect, previously the ac was so chilling that with fully loaded cabin, i would need to turn off occasionaly due to extreme cold in july august, i used to limit it to 1.
after replacing the pipe and refill the situation has changed, its not the same chilling any more, i checked following twice,
- gas
- condensor, washed, cleaned
- heat and cold knob and its wire under steering controls
- thermostate is perfect
everything is perfect but the cooling is now reduced to 80 % and even on 3, it does not cool that much. the mech said everything is ok, what can be the issue, the cooling pipes under hood are chilling, but inside its not.
what can be the issue.
thanks,
