Results 1 to 3 of 3
Thread: Vitz interior (dashboard) lights not working
    reaper1111's Avatar
    Jan 2016
    15
    Default Vitz interior (dashboard) lights not working
    I have been facing this issue since I changed the AC Air Filter which is located behind the left dashboard panel in Vitz 2006.
    The issue is, the inside lights (e.g. Gear panel lights/AC lights) don't turn on even after I switch them on from the handle behind the steering.
    I got it fixed once few weeks back, the electrician removed the left dashboard panel and pressed some fuse or something and the lights turned on. Couple days back it stopped working again.
    Any suggestions?
    Nabeel_Ali's Avatar
    Feb 2010
    24
    3,509
    108 Post(s)
    Quote Originally Posted by reaper1111 View Post
    Any suggestions?
    The fuse needs replacement
    Get a new one from electrician
    Sent from my SM-N920C using Tapatalk
    us000's Avatar
    Aug 2006
    28
    1,519
    73 Post(s)
    Check the fuses and some connector near the AC cabin filter might get loose, so you can check yourself too, or get it checked from some electrician.
    jiyo aur jeenay do
