Results 1 to 13 of 13
Thread: VITZ 2006 Gear Box issue
    hammadkhalid90's Avatar
    May 2016
    Default VITZ 2006 Gear Box issue
    Guys need some assistance,
    My vitz 2006 which i just got a few months back has developed an issue with its gear box.
    some time when i start to push the throttle pedal, the car stagnates at one speed i-e it stays at one speed but the engine revs start to climb as if the Transmition has been set to neutral. i check yesterday and the gear oil needs replacement , i took it to Toyota but they said they the gear box needs replacement and replacing the oil will not buy me time it will make things worse.
    any comments .
    and if there is a need for replacement can you guys suggest a good mechanic for the replacement since it is my first experience with an automatic.
    hash4u's Avatar
    May 2005
    38
    24,366
    18
    404 Post(s)
    13 Thread(s)
    13
    go to the junkyard area of which ever city you reside in
    you will have to swap a used one
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Quote Originally Posted by hammadkhalid90 View Post
    any comments .
    Those toyota morons. Had they checked the oil pressure with the scan equipment ot they give their fatwa by only oil color inspection. In which city you are located first of all get its trans oil pressure inspected with the help of Toyota Techstream scan tool then decide whether to replace or service this transmission. The problem will be noticeably resolved with the help of valve body servicing.
    capricornboy2000's Avatar
    Sep 2015
    27
    Mr. Hammad khalid so whattt did u do??
    Gear replaced or something else???
    Toyota guys have only option. Replace the gear box. They alsl adviced me same for gear jerk issue
    chinyoti's Avatar
    Sep 2005
    27
    11,951
    5
    107 Post(s)
    5 Thread(s)
    1)the car stagnates at one speed i-e it stays at one speed but the engine revs start to climb as if the Transmition has been set to neutral.
    2) i check yesterday and the gear oil needs replacement ,
    A CVT car drives like that, Since it doesn't changes gears, You only feel the rpms increasing. Many people i know have ruined their Honda City vario in such a manner (k gari gear slip kerai hai mechanic said gari beichdo)!
    Secondly, How did you on your own checked the CVT oil and inspected it?
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    Sep 2015
    27
    Is there difference in CVT and ATF Oil??
    chinyoti's Avatar
    Sep 2005
    27
    11,951
    5
    107 Post(s)
    5 Thread(s)
    Quote Originally Posted by capricornboy2000 View Post
    Yes obviusly
    Sep 2015
    27
    Whats the difference??
    And how will we know that either gear oil is cvt or atf?
    paend's Avatar
    Mar 2013
    35
    Default Parts available for toyota vitz from Quetta
    Dear if someone needs any vitz part from quetta I can make parts available to your cities....but people will have to wait at least for 1 week...
    Sep 2015
    27
    Yes y not
    I have PM u. Plz check
    399.ak's Avatar
    Oct 2015
    Swat
    19
    190
    Can y post some video of speedometer while accelerating that will be helpful
    How much is the car driven?
    Have y changed gear oil before?
    It depends on the gear oil may be it is burned post pic of gears oil
    If u r changing tranny oil first flush the tranny & put Toyota CVT oil tin pack
    It should get better
    But usually CVT are like this first the rpm increases to 5-6k by full throttle and then speed slowly increases
    Hence post the video so we may get some idea
  12. #12
    paki_snake's Avatar
    Dec 2005
    30
    128
    Changed gear oil 5 months ago...after that having issues with pick and acceleration....car engine produces alot of sound while shifting gears.
    Tried multiple tunings...throttle cleaning....fuel filter, fuel pump and manifold exhaust changed......still problem continues....a mechanic is suggesting gear box replacement....
    Vitz 2010
  13. #13
    Sep 2015
    27
    Got a transmission mechanic who reaolved my gear jerk issue
