Page 3 of 3 FirstFirst 123
Results 41 to 43 of 43
Like Tree4Likes
Thread: Engine Oil for Vitz 2006 KSP 90 1.0L
    vitz_2006's Avatar
    Jul 2012
    108
    2 Post(s)
    Default Engine Oil for Vitz 2006 KSP 90 1.0L Weaker Engine
    Experts .
    My Vitz 2006 model KSP90 1.0L has done approx. 107,000 km and its engine has gone weaker now. It has started reducing oil - approx 450 ml per 3.500 km(every oil change) which is 13% oil reduction per oil change interval. Also it gives white smoke (only) when FULL throttle is applied (but no smoke at all with normal driving)
    Experts ,including toyota dealership, have recommended me to switch to 20W50 engine oil to reduce wear and tear (though it will effect fuel consumption negatively) ; currently I am using 5W30 as recommended in the car manual.
    Questions :
    1. Is their suggestion correct ? .Any disadvantages of using thick oil apart from bad fuel consumption?
    2. Which 20W50 oil should I use - which one is the best in the market . Toyota oil or any other ?
    3. What is the recommended oil change interval for this particular suggested oil
  2. #41
    syedalidee's Avatar
    Jun 2016
    20
    Quote Originally Posted by syncview View Post
    text added in bold for clarification
    What youhave done brother is your problem resolved as i am facing same issue and toyota eastern said that my vitz has back compression as well
  3. #42
    syedalidee's Avatar
    Jun 2016
    20
    Quote Originally Posted by saboor73 View Post
    Compression seems good I wonder why Osama didn't perform wet compression test it would have gave a good idea of valve seals status
    from where icould get thistest done in karachi?
  4. #43
    syedalidee's Avatar
    Jun 2016
    20
    Ting ting anybody here?
    Quote Originally Posted by syedalidee View Post
