Results 1 to 2 of 2
Thread: Engine oil
    Newbie Follow
    Salmaniqbalrajput's Avatar
    May 2016
    Default Engine oil
    I got 2nd engine oil changed to my 2011 Vitz 38000km done from Toyota 3s dealer. They have suggested & used 20w50 grade oil. Last time i used Havoline 10w30 grade and it went superb. I am confused now as if Toyota people did wrong in suggesting me the right oil. Should i drain new oil immediately to save engine and use Havoline 10w30 again? Please suggest. Thanks
    tintin1's Avatar
    Jan 2014
    1,829
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    Go back to toyota and slap hard their so called expert who told you to use 20w-50 & 10w-30.
    The OEM recommendation is to use 0w-20. But this oil is not successful in PK.
    So the best available options are
    5w-20
    0w-30
    5w-30
    SN ILSAC-5
    these oils will give you best fuel economy and very long engine life with protection.
    there are many threads here already related to this question. why not search to get more informations.
    Be Addicted To Help Others.
