[QUOTE=alihaidershah;5105026]AOA,
Thanks a lot of reply. I live in Rawalpindi. I can also go to Islamabad. Do you know any places where I can go and get Ultra sonic cleaning?
Also, after how long should be fuel injectors cleaned? And If any liquid cleaner is used kindly recommend me which one to buy to get best results. The 150-200 one on Petrol Stations are fake and NEVER work. Kindly provide me with more information on which one to get as my car is driven 61000 but never had fuel injectors service.
Also, my local mechanic totally disagree with cleaning fuel injectors and was like lets take out the catalytic converter. He is also a guy who takes out my Denso Iridium Spark plugs and clean them with wire rotator machine and spray WD-40 on it afterwards as I recently discovered that Iridium spark plug get completely destroyed if cleaned that way. And he says it the write way as its Pakistan and blah blah blah. I am not taking my to him anymore as he is gonna further ruin things. Do you guys think my plugs are damaged now as I am pretty sure they are after being rotated against that Machine at least 4-5 times.
Kindly enlighten me.
Irridium plugs can go as long as 100,000 KM.
Cleaning a plug is an act of the past. Replace them at the required interval.
Try fuel injector cleaner. I have been using 3M, Liqimoly and found them to be good. Ask Toyota 3S for Toyota fuel injector cleaner. Yes Toyota does sell their own Toyota branded fuel injector cleaner.
WD40 is a lubricant as well as solvent but not volatile to be used for cleaning or washing spark plugs. This in nonsense. Replace the spark plugs at the earliest.
Change engine oil to 5W30 grade oil. liquimoly, Mobil 1, shall all are good brands.
