Results 1 to 5 of 5
Thread: Vitz 2005 gear jerks/sounds in reverse and forward
    capricornboy2000's Avatar
    Sep 2015
    27
    Default Vitz 2005 gear jerks/sounds in reverse and forward
    Facing the same issue of gear jerk in vitz 2005.
    But this issue appeared after a ghatia mechanic changed the temperature sensor under gear box chamber. He did nothing except open the gear chamber and close after temperature sensor replacement. Mechanic top up the CVT Oil and mix the old 3 litre oil with 1 litre new cvt oil.
    Plz guide any one what can be the reason of forward and reverse gear jerk just after initial acceleration keeping in view above scenario.
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Quote Originally Posted by capricornboy2000 View Post
    In which city you are located and get in contact with rehman autos a best place to visit for the toyota cvts and auto transmissions preventive maintaince service.
    Sep 2015
    27
    In Multan.
    Where is rehman autos???
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    In Multan.
    In rawalpindii. Way to far from you man.
    Sep 2015
    27
    Not possible.
    Any expert plz guide what is actual problem
