Results 1 to 6 of 6
Thread: ac not working in vitz 2005 model
    paend's Avatar
    Mar 2013
    35
    Default ac not working in vitz 2005 model
    Aoa Dear friends ,I have vitz 2005 model, in winters I got its gas filled because compressor was removed for some noise and according to ac mechanic he filled gas along with some bearing change(I dont know which bearing n noise was that perhaps it was not).however I used ac for one day and it worked ,but then i did not use it due to winters.now as i switch on ac it does not work however its fan switches on n car accelerates bit as i push ac button with out any cooling from ac.can some one plz guide me what can be the issue as i got it checked from mechanic.he says"gas is full but compressor is not working and I will have to replace it"
    paend's Avatar
    Mar 2013
    35
    any one please guide me?
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    267
    4 Post(s)
    which mech did you visit, if you are in isb, then visit abu bakar, universal car auto g 8, he is the best and cheap
    paend's Avatar
    Mar 2013
    35
    I am not in ISB dear,can you or some one guess what can be the issue ?
    imrananr's Avatar
    Jun 2014
    836
    5
    19 Post(s)
    Quote Originally Posted by paend View Post
    Re-Fill refrigerant and check for any leakages and get them arrested.
    If all is OK and AC is cooling then fine.
    If the above is done and there is no cooling then you may go for the compressor related issues.
    Don't leave a highway for a byway....
    paend's Avatar
    Mar 2013
    35
    ok let c today m going to check it....
