Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Like Tree1Likes
Thread: 1KR-fe and OBD2 port
    spiderman-17's Avatar
    Jun 2016
    106
    6 Post(s)
    Default 1KR-fe and OBD2 port
    Hi All,
    Any one used an obdII scanner with a toyota vitz 2009 (1kr-fe petrol engine) to read/clear error codes and monitor various sensors of the engine. it uses M-OBD ISO 14230-4 ?
    Thanks
  2. #21
    rkbladex's Avatar
    Nov 2014
    189
    6 Post(s)
    Quote Originally Posted by spiderman-17 View Post
    The settings are in the summary page where you click on connect to ecu
    The setting is called select ecu
    Ok i got it. Following is the settings which i used.
    Select ECU: Generic OBD II
    Protocol: OBD-II CAN
    - RKBladeX
    If you found my response helpful!!. Don't forget to press like button
  3. #22
    tintin1's Avatar
    Jan 2014
    1,842
    8
    61 Post(s)
    2 Thread(s)
    7
    5
    Quote Originally Posted by rkbladex View Post
    First download ELMScan Toyota Demo version software from Play store into your mobile and then Connect your device OBD in your car and connect ECU with above mentioned software if ECU is connected fine with that software then you need to purchase this software. Currently i using this software and it is good software that support all your requirement like coolant temperature and all sensors reading O2 sensor AFR sensor and also in this software you can see or clear all trouble codes.
    Demo version is free and has limited functionality but you need to do is to check whether this software can read reading from your car ECU. Paid version of this software will cost you around 600 PKR.
    I hope this help you...
    - RKBladeX
    Does it tell the engine working temperature also?
    if yes, then plz take few readings and post here.
    thanks.
    Be Addicted To Help Others.
  4. #23
    Jun 2016
    106
    6 Post(s)
    Quote Originally Posted by tintin1 View Post
    thanks.
    if you are referring to the engine coolant temperature, the green (cool) light on the dash goes off when it reaches 55c and the max I got when driving for long trips and/or in traffic is 85c (never heard the radiator fan spinning thus need to check at what temp the fan goes on, the outside temp in my country is around 28 to 30c
    Edit: fan starts at 95/96 celcius
    the coolant has been replaced a month ago using toyota super long life
    hope it helps
