Results 1 to 12 of 12
Thread: Need to Replace Engine in Vitz 2007 New Shape
    freelancepulp's Avatar
    Mar 2015
    27
    Default Need to Replace Engine in Vitz 2007 New Shape
    Hi All,
    My Vitz 2007 model need an engine replacement. The current one is no able to run AC in D mode and switching off the ignition. Can you suggest me best way to replace and how much it will cost.
    Thank you!
    Tanveer
    rkbladex's Avatar
    Nov 2014
    190
    6 Post(s)
    Did you scan your car?? is there any trouble codes logged in your car ECU?? When your car switch off the ignition right after you press AC button or some other scenario?
    I am asking this because i m also facing that kind of similar issue?
    What engine oil you used mostly?
    - RKBladeX
    If you found my response helpful!!. Don't forget to press like button
    Mar 2015
    27
    My Engine start vibrating on AC while I push the breaks on road otherwise it is working fine. It is only creating trouble while on D mode. I use ZIC oil. Toyota City motors suggested to replace AC compressor instead of Engine but all others said its engine that is able to bear the load of AC. Still confused...
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    Allah kher, ap ko bta du apne zrai se ke mechanics ki mafia bani hwi he, same is happening in isb/rwp, when you visit mechanic they say your engine is dead and need to replace, check proper mechanic, you might need to change your compressor or there might be wiriring issue, i faced this issue in my vitz and actually the ac wiring was connected with gear so that when you move to D and R mode, it starts shaking.
    Also the compressor might be faulty and it might be causng this problem.
    But be aware that there is a big mafia of mechanics that is growing these days, they have connections, they will tell you to change engine...dont do it...
    sufian_noshad's Avatar
    Mar 2006
    Rawalpindi
    31
    219
    5 Post(s)
    Quote Originally Posted by freelancepulp View Post
    Have a compression test done only that will tell if the engine needs replacement
    Sent from my iPad using PW Forums
    Fahad.Ayub's Avatar
    Aug 2013
    21
    1,959
    32 Post(s)
    Did you get the car scanned ?
    Did you carry out any sort of maintenance except the usual oil change ?
    Sent from my SM-G900F using PW Forums mobile app
    shazo's Avatar
    Aug 2010
    26
    3,418
    240 Post(s)
    7 Thread(s)
    Well i use to done my work at all motors workshop. They have every equipment required for confirming such cases and quite educated people are there to guide you best. You can visit them. Compression test, leakdown test is available over there. Search them over fb by allmotorautomotives or give call at 0333-4614073.
    Sent from my H30-U10 using PW Forums mobile app
    Mar 2015
    27
    Yes, that can be the reason, that is why I was hesitating to change Engine, the car is in excellent condition. This is just one minor problem. I will get it re-checked from allmotorautomotives in few days.
    Quote Originally Posted by sohelahmed View Post
    AlienX's Avatar
    May 2012
    Rawalpindi
    76
    2 Post(s)
    My car was also switching off with AC. It turned out to be a busted injector. Replaced it and it's all good.
    AlienX's Avatar
    May 2012
    Rawalpindi
    76
    2 Post(s)
    You are right, every time I went to mechanic he always insist on replacing the engine and saying mine is dying. It's correct to some extent as it's wearing out (86000 milage duh!) but no where close to dying. It still accelerates good, runs AC great and very few vibrations. Funny part is mechanic is suggesting to replace it for last 3 years.
    Changing engine also involves getting car papers redone for alteration. And there is also problem of checking if replacement engine is from theft or from a car used in crime.
    rkbladex's Avatar
    Nov 2014
    190
    6 Post(s)
    My car is also switch off with AC in middle of the road on low RPM or Speed and ECU record P1603 error code I still don't find a exact cause of this fault.
    - RKBladeX
  12. #12
    AlienX's Avatar
    May 2012
    Rawalpindi
    76
    2 Post(s)
    Quote Originally Posted by rkbladex View Post
    - RKBladeX
    Get the fuel injectors checked. As well as Fuel pump and filter.
