Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Like Tree4Likes
Thread: Vitz2013 is giving low Mileage
    mdaniyal's Avatar
    May 2016
    24
    Default Vitz2013 is giving low Mileage
    Asalamolikum
    I am newbie in this forum and recently i got Vitz 2013. I am a new car user and have not immensely experienced with car maintenance and warentari observed that my car is giving 9.0 mileage in city,how do i can improve the mileage while other Vitz owner have better.
    Your expert opinion is mandatory.
    Thanks
    hassan_mirza9's Avatar
    Jul 2008
    36
    236
    It all depends on how u drive......but tell u frankly 9 and 10 is the max milage u will get in vitz with ac on and dense traffic. .....so dont worry.....
    U can do following to inc milage
    New plugs
    New oil and filter
    New air filter
    O2 sensor replacement
    Hope it will help
    Sent from my SM-A510F using PW Forums mobile app
    afowad's Avatar
    Mar 2016
    54
    How is the mileage on highways
    Sent from my SM-N900 using PW Forums mobile app
    imrananr's Avatar
    Jun 2014
    849
    5
    19 Post(s)
    Quote Originally Posted by mdaniyal View Post
    Asalamolikum
    Thanks
    1) Use low viscosity engine oil (recommended one), 5W30 API SN, or ILSAC GF-5 full synthetic for better fuel consumption.
    2) Replace old air filter with Toyoya genuine air filter.
    3) Use stock wheels size 165/70 r14 ( I assume it is Vitz 1.0 L)
    4) Get rid of extra stuff from the trunk.
    5) Get the throttle body serviced (if required).
    6) Replace spark plugs ( if required).
    7) check O2 sensor for proper functioning.
    8) Maintain proper air pressure in the tyres. (34 psi for 165/70 r14)
    9) carry out wheel alignment and balancing (if required).
    10) Replace tyres if worn out. ( measure tyre tread).
    You should get around 14KM/L fuel average in city and minimum of 18 to 19KM/L on highways. Use HOBC petrol.
    Don't leave a highway for a byway....
    mdaniyal's Avatar
    May 2016
    24
    Thanks for your opinion... probably low mileage due to replaced the tyres on 185/70 size. otherwise everything have been checked by Toyota Ravi.
    Sent from my H30-U10 using PW Forums mobile app
    imrananr's Avatar
    Jun 2014
    849
    5
    19 Post(s)
    What viscosity oil are you using?
    mdaniyal's Avatar
    May 2016
    24
    Vitz2013 is giving low Mileage - 27681a5f6e9d3cd5a19edb0672f96b78
    FaatehRehman's Avatar
    Apr 2010
    Rawalpindi
    25
    222
    You are using non-recommended oil for Vitz. Assuming your car has a 1000 CC Engine (1KR-FE), 0W-20 is the recommended oil while 5W-30 can also be used as an alternate. You are using 20W-50 which is way thicker/heavier and it is one of the reason of low mileage. Do not expect miracles after changing oil to proper grade but it will most certainly improve mileage.
    spiderman-17's Avatar
    Jun 2016
    106
    6 Post(s)
    Quote Originally Posted by FaatehRehman View Post
    5W30 is the recommended oil according to the 1KR-FE Service Manual
    imrananr's Avatar
    Jun 2014
    849
    5
    19 Post(s)
    Very sad to see all this. I my previous Mail on this page I clearly mentioned 5W30 engine oil should be used. You never bothered and you are using this piece of **** oil brand in a JDM. The main reason for high fuel consumption. Brother, you will ruin your engine with this thick oil. Use 5W30 full synthetic API SN or ILSAC GF-5 certified oil. Liqimoly, Shell, Mobil 1, Total are good brands.
    Jun 2016
    106
    6 Post(s)
    80% of engine wear and tear occurs during cold startups, with that oil (guard 20w50) your are increasing the 80% to more then 150% (with 20W)
  12. #12
    hamza_xeg's Avatar
    Aug 2009
    Abbotabad
    20
    8,793
    94 Post(s)
    8 Thread(s)
    A friend is getting same mileage in city with AC and with medium sometimes heavy foot.
    The men are back. @TGT.
  13. #13
    mdaniyal's Avatar
    May 2016
    24
    Thanks everyone for the advice. Let me change it immediately.
    Can i use Toyota's synthetic oil.
  14. #14
    mdaniyal's Avatar
    May 2016
    24
    Toyota Ravi have only 5w50. Is that ok
  15. #15
    399.ak's Avatar
    Oct 2015
    Swat
    19
    190
    It is fine but not too good please use toyota 5w-30 or any other good brand also if possible change tyre size to 165 or 175
  16. #16
    r18a's Avatar
    Feb 2016
    110
    I would recommend you shell helix hx7 fully synthetic 5w-30 engine oil.
    Sent from my SM-G900F using PW Forums mobile app
  17. #17
    awzubairi's Avatar
    May 2015
    9
    Quote Originally Posted by spiderman-17 View Post
    What is the recommended oil for 4g13 engine?
    Sent from my QMobile X700i using PW Forums mobile app
  18. #18
    imrananr's Avatar
    Jun 2014
    849
    5
    19 Post(s)
    Toyota TGMO in Pakistan is not available in 5W30 ( please confirm), but 10W30.
  19. #19
    mdaniyal's Avatar
    May 2016
    24
    Vitz2013 is giving low Mileage - d167faa23d5273fda42fa11916320751
    This is the oil that i recently change
  20. #20
    399.ak's Avatar
    Oct 2015
    Swat
    19
    190
    It is a little heavy for 1kr-fe
    Use 5-30 or5-40
