Results 1 to 19 of 19
Like Tree2Likes
  • 1 Post By capsat
  • 1 Post By afarooqi
Thread: Vitz 2011 check light issue
    asim405's Avatar
    Jul 2009
    28
    Default Vitz 2011 check light issue
    Dear All,
    I have vitz 2011 since 4 years , works absolutely fine , but recently show check engine lights I have discussed with mechanic he said your catalytic converter is chocked needs to be clean along with the O2 sensOr.
    Anybody tells me where can I get the service of catalytic converter In karachi ......
    Or suggested any good workshop In Karachi .
    Thank you
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    0300 2237538 Irshad, Get it scanned and work according to error code. only by CHECK light .. no expert can determine exact fault. such tin box mechanics do experiments at your cost. exercise caution please
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Quote Originally Posted by capsat View Post
    Professional Diagnosis expert can detect the fault easily with scan equipments if there is no check engine light is present. But a tin box mechanic will surely mess up with the vehicle and surely do some new experiments on your vehicle at your risk and cost.
    rkbladex's Avatar
    Nov 2014
    189
    6 Post(s)
    Is that guy good because i am also facing Check engine light issue on my Vitz? Can you guide me complete address of his workshop?
    - RKBladeX
    If you found my response helpful!!. Don't forget to press like button
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    please pickup phone dial n ask, the diagnostic charges apply if you choose not to get work done by him.
    good ? @Naweed @afarooqi can comment of quality & work charge
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    Irshad is good .. knowledgeable and experienced
    first thing to do in check engine light is try resetting ... if it doesnt go then u can asses general area by symptoms like a chocked CAT will kill the acceleration and pick up, etc
    "You have not lived today until you have done something for someone who can never repay you."
    AlienX's Avatar
    May 2012
    Rawalpindi
    69
    2 Post(s)
    Quote Originally Posted by asim405 View Post
    Dear All,
    Thank you
    Get the O2 sensor cleaned. It may have residues on it. And yes Catalytic Convertor can cause engine light but there may be something else. Get the vacuum unit checked also for any leaks.
    afarooqi's Avatar
    Jul 2006
    38
    915
    20 Post(s)
    Sorry for late reply.
    Irshad is way ahead of now-adays so called mechanics. Work by the book, and understands his work actually.
    Prepare for the worst, Hope for the best.
    shashmi8080's Avatar
    Jul 2016
    30
    5
    hi bro .... i have vitz 2005 ... same problem check light . my mechanic also said to change cat converter and O2 sensor .... did u change it ? ? ? has it worked ? ? ? and if yes then how much did it cost you ? will be waiting for your reply ...
    shadab_lodhi's Avatar
    Feb 2012
    Rawalpindi
    82
    Nothing could be done unless you get your car be scanned and come up with the code number and Freeze Frame Data. Diagnostic Trouble Codes are the most accurate way which lead to reach the actual problem.
    shehzadakbar12's Avatar
    Sep 2016
    7
    Mine was giving same problem. Checked it on computer and replaced the oxygen sensor before catalytic converter. Problem solved. Good consumption and no engine light
  12. #12
    AlienX's Avatar
    May 2012
    Rawalpindi
    69
    2 Post(s)
    Check engine light can be due to any number of issues. Which include but not limited to O2 sensor, ignition wires, busted spark plug, faulty injector and sometimes ABS malfunction. If you got engine light at high speed, then it's probably O2 sensor.
    Mine used to light up whenever I did over 70km/h and turned off after restart. It turned out to be a faulty fuel injector and I never got the light again after replacing.
    But your first step is to scan the car.
    Sent from my LG-D855 using Tapatalk
  13. #13
    Jul 2016
    30
    5
    marwa diya yar aap ney .... i went to irshad for check engine light issue .... he told me to change cat.converter ... done ... change 02 sensor ... done .... change body throttle ... done .... check light is still there .... he's lil bit ashamed now and gave me the new error sheet and told me to ask someone about that ... cost me around 25000 for nothing ...
  14. #14
    Jul 2016
    30
    5
    m having the same problem ... i've changed cat.converter, o2 sensor, body throttle check light is still there ... any advice ?
  15. #15
    spiderman-17's Avatar
    Jun 2016
    106
    6 Post(s)
    Quote Originally Posted by shashmi8080 View Post
    Did you scan the car to see the error code?
  16. #16
    Newbie Follow
    scarykiller2000's Avatar
    Apr 2010
    27
    I am also having the same problem in my 2005 model vitz..... I have a strange issue...... When ever i cross the speed of 70 km/hr the check engine light turns on... if i turn off my car and start it again its gone...but after 70 km/hr or if i go hard on the accelerator then the check engine light turns on....
    i have gone through all the works.
    throttle body
    o2 sensor
    cat converter
    change of gear oil
    but of no use
  17. #17
    walls's Avatar
    Feb 2010
    30
    213
    2 Post(s)
    I am driving my vitz from 2011 with the same thing.. suddenly check engine light on but it happens once or twice in a week. And after restart it is gone Error found after scan was some acceleration type. But now I don't care as drive is fine and have used this car more than 100,000 km.
    Sent from my GT-I9192 using PW Forums mobile app
  18. #18
    Jun 2016
    106
    6 Post(s)
    Quote Originally Posted by walls View Post
    Check connections for corrosion if the CEL is intermittant
  19. #19
    AlienX's Avatar
    May 2012
    Rawalpindi
    69
    2 Post(s)
    Quote Originally Posted by scarykiller2000 View Post
    throttle body
    o2 sensor
    cat converter
    change of gear oil
    but of no use
    I had exact issue. It's common knowledge that you will get engine check light if you remove catalytic converter or your O2 sensor has carbon/residuals on it. Even though car works fine otherwise. If you notice the dashboards of other vitz on road or signals, almost 50% of them has engine check light.
    In my case, it was a malfunctioning fuel injector. Once replaced (Kabli/1000rs) the light came back only once or twice for few seconds, which also resolved after replacing a corroded harness/grip. Don't worry about engine check light, it usually means to have your car checked soon. It may just be asking a regular maintenance like replacing spark plugs or clogged cat-convertor.
    I heard a rumour that Pakistan is shifting to better quality fuel from Nov-2016, may be someone would confirm if it's true.
    ( Personally I have started to dislike JDM cars, good quality build but have lots of engine and cvt problems/ batteries reaching end-of-life or tempered odometers. Way too many variables to worry about.)
