Results 1 to 16 of 16
Like Tree2Likes
  • 1 Post By hydaxxx
  • 1 Post By AlienX
Thread: 2013 vitz 1.0 F vibration issue at idle
    hydaxxx's Avatar
    Mar 2009
    Peshawar
    30
    75
    2 Post(s)
    Default 2013 vitz 1.0 F vibration issue at idle
    Hey guys purchased a 2013(/2016 import) vitz recently for my wife, a very good 4 grade car with clean interior.
    Issue no.1
    The car used to vibrate alot on idle, i cleaned the throttle body changed plugs, air filter the problem still persists!. Help needed
    Issue no. 2
    The car gear ratios were very akward, While tuning the car, scanner showed transmission error and upon inspection and draining transmission oil, ATF was fed instead of CVT transmission oil lol. Furthermore the car ratios are now improved but still it takes ages to change the gear. ( i hope this is normal with these vitz as iv never driven one before?)
    Help before i eat my brains sell it off !
    Regards
    nawan885's Avatar
    Jan 2008
    36
    601
    8 Post(s)
    No vibration at idling .. I didn't change any fluid except engine oil and I didn't find any vibration.
    Gears changing is also good..no issues we have faced with 2013 56k on odo
    Sent from my SM-A510F using PW Forums mobile app
    blueazure's Avatar
    Jan 2012
    369
    9 Post(s)
    a bit vibration at idle is normal , ( small 3 cyl 1kr engine ) . you can always go to toyota shop and ask them to slightly increase the idle rpm through their diagnostic tools
    AlienX's Avatar
    May 2012
    Rawalpindi
    69
    2 Post(s)
    Quote Originally Posted by hydaxxx View Post
    Issue no.1
    Issue no. 2
    Regards
    There are no gears in the car as it's CVT. Get the ATF fluid drained ASAP, It's not designed for CVT, only use Toyota genuine CVT fluid.
    Vibrations in Vitz is normal. Always mix high octane fuel in the tank to delay the ignition slightly and avoid knocking (3 cylinder).
    You may be looking for gear changing but there isn't one. Vitz will never launch, this is hardest part of understanding vitz. It will never spin the tires even if you floor it as power transfer is linear. So keep a light foot on throttle.
    Seriously, Get the ATF fluid changed ASAP, use CVT fluid only. I am not sure who in his right mind suggested you to use ATF fluid. You may be looking at 50K loss for replacement if something goes wrong.
    AlienX's Avatar
    May 2012
    Rawalpindi
    69
    2 Post(s)
    Quote Originally Posted by blueazure View Post
    It cannot be done for vitz. At least for JDM imported ones.
    COOLTAHIR's Avatar
    Feb 2011
    Select City
    19
    4,702
    9
    132 Post(s)
    3 Thread(s)
    to all looking for solution for vibration,
    perform Idle Learn procedure,
    search on google and you'll find the pic,
    when i unplugged the battery terminal and connected back, car started vibrating heavily, i performed idle learn process it went 50% and after driving 2 3 days it came back to its normal position ALHAMDOLILLAH
    FeeL YoUng DriVE YoUnG......
    hydaxxx's Avatar
    Mar 2009
    Peshawar
    30
    75
    2 Post(s)
    Quote Originally Posted by AlienX View Post
    Asalamalaikum,
    Sorry for the delayed response as i was away, yar God knows who put atf in this car as it was there when i bough the car and the scanner detected it. Changed it on the very first day and now im living with the vibration might sell it off in near future
    hydaxxx's Avatar
    Mar 2009
    Peshawar
    30
    75
    2 Post(s)
    Been there done that #Nothing
    chinyoti's Avatar
    Sep 2005
    27
    11,952
    5
    107 Post(s)
    5 Thread(s)
    Cutting out everything.
    Here's what you need to do.
    1) get your car tuned from toyota on the toyota computer. Only that is how vibration issues get resolved. When ever you replace your battery the battery wala needs to put a battery on the terminals or else it's going to come back again.
    2) a cvt transmission is a continuously variable transmission hence no gears. You'll often feel gears slipping I.e increasing engine sound but no speed.
    The car drives differently on different situations. Sometimes you'll feel it being sluggish some times it will on the same route. Fuel and driving styles matter.
    3) since you have made a mistake of using atf instead of cvtf make sure you get every inch of atf out.
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    hydaxxx's Avatar
    Mar 2009
    Peshawar
    30
    75
    2 Post(s)
    Quote Originally Posted by COOLTAHIR View Post
    Name:  ImageUploadedByPW Forums1469385126.949130.jpg
    Are you talking about this?
    COOLTAHIR's Avatar
    Feb 2011
    Select City
    19
    4,702
    9
    132 Post(s)
    3 Thread(s)
    yes exactly
  12. #12
    reaper1111's Avatar
    Jan 2016
    15
    I guess I should share my experience here as well. I had this extreme vibration issue in my Vitz as well, It boggled for the first couple days even though my mechanic had his concerns about the foundation of the engine to be broken I didn't pay heed to his observation at first and after a couple days when the intensity of the vibration increased I had to get it checked.
    After some inspection, the foundation (left side below battery panel) was broken (in half) replacing that almost reduced the vibration.
  13. #13
    AlienX's Avatar
    May 2012
    Rawalpindi
    69
    2 Post(s)
    I can confirm. Idle re-learn procedure works.
    Sent from my LG-D855 using PW Forums mobile app
  14. #14
    syedalidee's Avatar
    Jun 2016
    20
    Could you please ellaborate as i am failed to understand and facing same issue
  15. #15
    syedabdullah941's Avatar
    Sep 2016
    17
    Can you share link for the idle learn procedure
    Sent from my XT1254 using PW Forums mobile app
  16. #16
    b_zaheer2001's Avatar
    Nov 2016
    6
    I hav solved the vitz vibration issue on idle.so can contact me 03227041551
