Results 1 to 5 of 5
Thread: P1585 Acceleration sensor circuit
    goodfriend_pk's Avatar
    Jan 2009
    33
    7
    Exclamation P1585 Acceleration sensor circuit
    Few days back i have changed the seat covers and then CAR compressor was changed after that following error code has started appearing on computer initially with no light but now there are two errors started coming.
    P1589 Acceleration Learning Value error.
    I tried to celebrate the zero point celebration but it give error acceleration sensor circuit error need your help to resolve the P1585 please guide.
    Regards,
    Omer
    I am The Grim Reeper.... Please dont block me @PW .. Im here just to take your soul !!
    AlienX's Avatar
    May 2012
    Rawalpindi
    75
    2 Post(s)
    Quote Originally Posted by goodfriend_pk View Post
    Regards,
    Omer
    Zero point calibration is for steering.
    @rajaatta
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Quote Originally Posted by AlienX View Post
    @rajaatta
    No its for deceleration sensor ( yaw rate sensor) you can say in some cases. But in vitz its for deceleration sensor.
    AlienX's Avatar
    May 2012
    Rawalpindi
    75
    2 Post(s)
    Quote Originally Posted by rajaatta View Post
    Oh. Okay!
    Sent from my LG-D855 using Tapatalk
    shadab_lodhi's Avatar
    Feb 2012
    Rawalpindi
    82
    P1589
    Use a scan tool or Techstream and calibrate deceleration sensor. While performing the calibration follow on screen instructions. You can do the calibration by clicking Engine and ECT> Utility> Reset Memory> After that click "deceleration 0 point calibration" while you do that make sure that your car IGN switch is "ON", hand brake pulled and your gear shift is on "P” or Neutral. At last perform the CVT Oil Calibration.
    Some automatic transmission DTCs cause the MIL to come on. If the MIL is on and no DTCs are indicated in the EFI system, select the A/T system, and check for automatic transmission DTCs.
    If the problem persists, check the Yaw rate sensor position for tilt or replace the Brake Actuator Skid control ECU (ABS actuator assembly).
Tags for this Thread
