Results 1 to 3 of 3
Thread: Oxygen Sensor Problem
    engineer.shahidch's Avatar
    Sep 2015
    Default Oxygen Sensor Problem
    Dear Friends. I have vitz 2010, 1000 Cc. I m its first user. I have driven it 62K Km. Last mont, it got engine check light. After scanning, it was "Catalytic System Efficiency below threshold (p0420)" error. Mechanic advised me to clean catalytic converter. I got it clean. After refitting catalytic converter, I just drove 2 km and again check light was on. Again after scanning, it was a new trouble code. It was "A/F Sensor response slow " error. I cleaned the sensor twice but error is still there.
    Anyone guide me how to get rid of this problem permanently?
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    If the dtc is of oxygen sensor slow response then its time to replace it with a brand new one. Get it done and your problem would be resolved.
    Sep 2015
    Dear Raja. Thank u. Can I replace it with the used sensor. If i buy the new one, which brand is compatible with ECM of vitz? Can it will b useful to experiment to replace it with other car's sensor to verify the problem? Second thing how it is possible that sensor is malfunctioning do earlier ?
