Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By sohelahmed
Thread: Vitz Ground Clearance
    drag0nslayer's Avatar
    Jul 2016
    33
    2 Post(s)
    Default Vitz Ground Clearance
    AssalamoAlaikum!
    Advice needed regarding ground clearance of vitz just bought, Alhumdulilah ride is great issue is just its touching on speed breakers, so what you guys suggest to install spacers or what ?
    Thanks
    Jul 2016
    33
    2 Post(s)
    anyone?
    zayn05's Avatar
    May 2016
    12
    Spacers will make your ride stiff
    Sent from my SM-N9005 using PW Forums mobile app
    saad.nitrate's Avatar
    Jul 2012
    13
    You can either:
    1) Install tyres with more height, I replaced my stock tyres with Yokohama Advan DB 165/65/r13 while the factory fitted tyres had a height of 60, a mere increase of 5 had a huge change in the ride height which reduces the underside collisions by a huge margin
    2) Get spacers installed between suspension, also known as suspension plates if you aren't satisfied with the above option.
    goldenstripes's Avatar
    Oct 2014
    31
    49
    2 Post(s)
    Get 1 inch spacers i stalled
    But only for rear tyres
    It costs 800 for the spares + labour
    Cheaper option than changing tyres...
    And check tyre pressure as well - should be 30...
    akash190's Avatar
    Feb 2011
    Kharian
    22
    1,399
    8 Post(s)
    Quote Originally Posted by goldenstripes View Post
    Any difference in drive after ?
    Sent from my ALE-L21 using PW Forums mobile app
    A real driver knows exactly what's in his car.
    Oct 2014
    31
    49
    2 Post(s)
    I had them installed immediately on getting the car - plus i drive only incity - karachi - speed 40-80 kmph range - so cant give confirmed state
    But personally i don't really feel any major difference ...
    And between car hitting every second speed bump and a slight reduction in drive - i choose not hitting every other bump...
    humzafudda's Avatar
    May 2015
    32
    Install bigger tyres than it would not touch ground . I also had done this in my vitz. Another advice for not hitting bumps is to drive the car in snake (zigzag) pattern at bumps ,it would help in not touching bumps.
    sirdneo's Avatar
    May 2013
    84
    4 Post(s)
    Quote Originally Posted by drag0nslayer View Post
    AssalamoAlaikum!
    Thanks
    Agar gari ka agla tyre easiliy nikal jata hy aur gari beech sy lagti hy to sasta solution hy ky rear shocks main spacer dalwa lo, normally 600~800 main dal jayee ga.
    Agar gari ka agla tyre nikalty hi lag jati hy phir tumko charo tyres change kerny pary gy.
    Default size of Tyres is generally 165 or 155, You better install 175 or 185 tyre. If will give you sufficient ground clearance. This is best soltuion.
    talhabinomar's Avatar
    May 2011
    26
    2,472
    38 Post(s)
    I had installed the 1.5" spacers in the rear suspension back in 2013, it helped alot, the ride is little unstable at high speed like around 155-160 km/h, but how often do you drive that fast. So it is a good solution with minimal cost
    sohelahmed's Avatar
    May 2007
    Rawalpindi
    276
    4 Post(s)
    no matter what u do, it will hit the bumps...when there are passengers at back....
  12. #12
    Newbie Follow
    confiz.android2's Avatar
    Dec 2016
    Default do i need to install spacer on rear tyers as well front tyer ?
    Hi
    do i need to install spacer on rear tyers as well front tyer ? or installing spacers only on rear tyre will help in avoiding hitting to the speed breakers?
    Thanks
