Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Like Tree3Likes
Thread: Vitz fuel pump suggestions required
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    Default Vitz fuel pump suggestions required
    Aoa
    My vitz taking long self when parked for a while..
    I am told to change the fuel pump by various mechenic and Electricion
    My question is which type of Fuel pump I must get
    1. Kabli only fuel pump not complete set?
    2. Kabli complete fuel pump set
    3. local market fuel pump only
    Regards
    Faizan
    Sent from my GT-I9192 using PW Forums mobile app
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    I am facing the same issue, going to change it tomorrow insAllah
    Go for local chinese made one. Kabli ones will already be blocked enough 😂
    I am getting it for approx 1300 in bahria town rawalpindi. Change only fuel filter, no need to change fuel pump if it is original (Denso) made, else change it too, it can be though replaced with a kabli one
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    Quote Originally Posted by m_umairr View Post
    Acha
    Ap aj change karwain
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Quote Originally Posted by faizanali View Post
    Acha
    Cost for original fuel filter is 7700. If you can bear it, go for it.
    I was busy, could not do it. Will change it on weekend.
    Waise apki ijazat ka shukria Vitz fuel pump suggestions required - smiley tongue outVitz fuel pump suggestions required - smiley tongue outVitz fuel pump suggestions required - smiley tongue outVitz fuel pump suggestions required - smiley tongue out
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    Then update how is the experience
    I have been told that fuel punp is week not filter choked
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Then you should change both of it man. Fuel pumps usually burn out of vitz 1.0. I had to change 2 pumps in 1 year..
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    Ahan
    Today fuel was at end and luckily found high octane
    After pouring high octane car drive has imprven remarkably and not taking long self as before..
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Ahan
    I use hi octane, if by any chance i can find it.
    Try using Hi octane always and get fuel from Shell pumps.
    But you might need to still change the pump, as super fuel might have damaged it.
    In my case i disconnected battery terminal negative one for 5 minutes to reset ECU settings, and it didn't take long self today. Might need to check more on it
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    Hmm that's good
    I used to do same removing terminal thing with my Santro
    Will try on vitz too
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Hmm that's good
    @faizanali,
    An update regarding fuel pump.
    I changed it yesterday with a local one and my car was not starting up.
    I came to knew later that only genuine filter can be replaced with the faulty one, else Vitz being a computerized car, won't take any petrol and won't start up.
    So i had to go for the genuine one, worth 7700
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    Ahan
    Ok. Mean you have change complete set.
    2 days passed my car not taking long self..
    Let's see what happened next
    As this long self problem was from last year and suddenly gone now as I planned to change fuel pump
  12. #12
    haseeb.basharat's Avatar
    Mar 2015
    1,630
    42 Post(s)
    Bro, do not change complete fuel assembly. Change the fuel filter and it's (jaali).
    You can do the same thing after every 50,000kms.
  13. #13
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Not complete set, Only fuel filter which holds the fuel pump needs to be replaced, not the complete assembly
    Long selfs are because of bad fuel, hi octane will surely help.
    It's not linked with long selfs, with the passage of time due to bad fuel, it does gets clog.
    Sometimes within 100k kms and sometimes above it.. You might need to change it either way
  14. #14
    Mar 2015
    1,630
    42 Post(s)
    Long self have always been linked to clogged fuel filter or less air.
    Have been the same thing in my corollas from last 4th generations
  15. #15
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Quote Originally Posted by haseeb.basharat View Post
    True, bad fuel eventually leads to fuel filter blockage. I said the same thing too 😊
  16. #16
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    What is the cost to change fuel filter??
  17. #17
    Mar 2015
    1,630
    42 Post(s)
    Including parts & labour
    2000-2500rs.
    Choose a good mechanic though. One leakage in a pipe can be fatal
  18. #18
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    Hmm ok.. thats not that much high..
    Thanks bro
  19. #19
    mee.neo's Avatar
    Aug 2016
    6
    I had same issue on vitz 2004 removed fuel pump and checked on bench it worked completely fine even after 12 years. Turned out problem was with throttle sensor. Replaced it and it solved many issues like poor acceleration and also improved milage. Trust me dont follow the mechanics blindly. Fuel pumps last for lifetime of engine.
  20. #20
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    I will get my car proper checked
    Engine Tuned
    Throttle body service
    Computer scanned
    Etc etc
    As from more than a year no mechenic have touched my car... may be some maintenance needed like plugs or sensor cleaning etc
