Page 1 of 3 123 LastLast
Results 1 to 20 of 52
Like Tree2Likes
Thread: ELM OBD2 Portable device compatibility with vitz 2008
    deathstroke51432's Avatar
    Apr 2016
    N/A
    25
    20
    Default ELM OBD2 Portable device compatibility with vitz 2008
    I bought one ELM OBD2 Portable device and tried to use it using Torque pro app. What I dont understand is that it gives the problem of " unable to connect to ECU". So I want to ask, does it work with vitz 2008 and if yes, any help would be appreciated and will be grateful
    Regards
    Sent from my D6633 using PW Forums mobile app
    spiderman-17's Avatar
    Jun 2016
    106
    6 Post(s)
    Quote Originally Posted by deathstroke51432 View Post
    Regards
    Your car is not obd2 fully compliant if it's a Japan domestic import (i have 2009 which is JOBD)
    Wait for next update of torque pro ( next week) i have beta test it and it connects (check/clear error codes) BUT, you will need extended pids to monitor car sensors and you must use atsp6\natsh7e0 as initialising string
    shadab_lodhi's Avatar
    Feb 2012
    Rawalpindi
    85
    Do the following:
    1. Pair your Bluetooth device.
    2. Go to Settings and select Bluetooth.
    3. Next on settings menu go to Bluetooth settings, choose Bluetooth device, select your device and click OK.
    4. Rest of the items are optional.
    5. Select menu (Settings, Vehicle profile, Quit), Select Vehicle Profile and enter your vehicle on the guided menu.
    6. Insert your device in OBD2 socket under the Dash on lower right corner near the hood opener, switch ON the ignition and wait for the device to connect.
    Hope that works. Good Luck.
    shoaib20695's Avatar
    Jun 2015
    Select City
    7
    Is vitz 2008 support by obd2
    Sent from my HTC_M8x using PW Forums mobile app
    Feb 2012
    Rawalpindi
    85
    Yes it supports.
    haseebhamid's Avatar
    Feb 2009
    Rawalpindi
    31
    23
    I'm also not able to connect to the ecu using torque pro. See the snap below. I have 2008 Vitz.
    Sent from my HTC One_M8 using Tapatalk
    Feb 2009
    Rawalpindi
    31
    23
    rkbladex's Avatar
    Nov 2014
    190
    6 Post(s)
    Quote Originally Posted by spiderman-17 View Post
    Spiderman can you share extended pids and initialized string for vitz I also have vitz 2009 model and my car ECU also don't connect with torque pro app can you help me out i want to use torque pro app? If you don't conformtable to talk here do PM me.
    - RKBladeX
    If you found my response helpful!!. Don't forget to press like button
    Jun 2016
    106
    6 Post(s)
    Quote Originally Posted by rkbladex View Post
    - RKBladeX
    Go in adapter settings of torque pro, scroll down and tell me what version you have installed
    Feb 2009
    Rawalpindi
    31
    23
    What does the error code p0016 crankshaft position - camshaft position
    Corelation bank 1 sensor A
    Means
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    I also want to get an obd 2 scanner cable to attach with my anroid or iPhone-5
    It will be available in lahore market.. ?
    Sent from my GT-I9192 using PW Forums mobile app
  12. #12
    Jun 2016
    106
    6 Post(s)
    Quote Originally Posted by walls View Post
    You need a Bluetooth or wifi adaptor to connect to your phone (no cables), i suggest android because you can run torque pro (playstore) which in my opinion is one of the best to monitor life sensor data and read/clear fault codes. You need some research to make it work cos if your car is a jdm it is not obd2 .
    I can help you to connect torque to ecu
  13. #13
    Feb 2009
    Rawalpindi
    31
    23
    I have Vitz 2008 1kr-fe ,is it jdm or odb2, how do I check?
  14. #14
    auto_rebel's Avatar
    Aug 2016
    44
    I dont.think.elm.support.vitz I have try before
    Sent from my ALE-L21 using PW Forums mobile app
  15. #15
    Jun 2016
    106
    6 Post(s)
    Quote Originally Posted by auto_rebel View Post
    If the elm adapter supports 15765-4 CAN protocol, then yes it can talk to ecu of vitz besause that is the protocol vitz uses
  16. #16
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    I have second generation vitz 1krf engine
    That will called a jdm car.. it is having an obd2 port but it will not able to connect to software. What should I do then 😐
  17. #17
    Jun 2016
    106
    6 Post(s)
    I assume you want to use it on Android phone so, Do you have an obd adaptor (wifi or blutooth)? i recommend bluetooth.
  18. #18
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    I want to purchase something
    As you recommend Bluetooth then I will buy it. As it available in market too by the name of ELM327 Bluetooth obd2 mini. Will it work or I should find something else for my car?
  19. #19
    Jun 2016
    106
    6 Post(s)
    My adapter is obdlink mx and it works perfectly with my toyota vitz 2009 1KR-FE engine.
    Do not go for cheap adapters and avoid the ones that say elm327 Version 2.1 because 98% of them are fake or with a cloned mac address eg 11:22:33:44:55:66:77:88
    The protocol is ISO 15765-4 CAN {11bit 500k baud) so make sure it is in the list of supported protocols when buying the adapter
  20. #20
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Ok
    Thank you for guidance
    I will search some as you recommend.
    Will update Sir.
