Results 1 to 5 of 5
Thread: White smoke from my Vitz after removing cat converter
    waqasaslam1's Avatar
    Jun 2012
    8
    Default White smoke from my Vitz after removing cat converter
    Dear Fellows,
    Some days back the pick of my vitz 2008 was not proper.My mechanic told me to remove Cat converter.After removing cat converter the acceleration is much much better and fuel consumption is also very good..But there is one problem that i noticed.when i push race pedal to hard in idle position,the car gives white smoke...is it a problem and what can be the possible reason??????
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    Get it checked again
    head valves etc..
    Sent from my GT-I9192 using PW Forums mobile app
    pistonhead's Avatar
    Dec 2009
    86
    1,439
    24 Post(s)
    Pretty soon, you will get a check engine light as well... Removing that cat on is never advisable.
    Quis custodiet ipsos custodes?
    Teeboyuk's Avatar
    Sep 2012
    Other
    1,608
    8 Post(s)
    i think you've found out why the cat was blocked
    Pakistan.. Toyota hilux..golf mk2 gtd..rolla 2.0d..nissian sunny.. Yamaha pw 50.. Coventry uk....audi v8 d11..golf mk2 rallye..honda crx..evo 8..golf mk2 gtd..Vauxhall insignia..
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    What engine oil you are using
    If recently started a fully senthytic oil... check for oil decreesing.. get it checked by your mechenic as soon as possible
