Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By mdaniyal
Thread: Vitz 2013 Self start issue
    mdaniyal's Avatar
    May 2016
    24
    Default Vitz 2013 Self start issue
    A month ago i buy Vitz 2013. car was parked for 13 days and never started during this time.
    Today i try to start the car but didn't engaged the self, somehow i manage to arrange the alternate battery and car was started...so i kept started 2 hours.
    Later on after 1 hour i try to start again but the face same issue as before and again didn't pick the self.
    Please let me know that i have to replace the battery or is it battery charging issue.
    Your expert opinion is awaited
    us000's Avatar
    Aug 2006
    28
    1,519
    73 Post(s)
    most probably it is the battery issue,
    some electronics in the car stay ON all the time, (consumes very less power)
    but if your battery was old, and car was consuming some amount of energy for 13 days, so battery might gone completely dead.
    if the battery is liquid based, then check the water level.
    and if you dont have any idea about batteries, then goto some battery shop and get your battery checked.
    jiyo aur jeenay do
    DUDE007's Avatar
    Oct 2011
    2,033
    104 Post(s)
    Check crank voltage. It shouldn't go below 10.5 volts.
    Check gravity of cells when battery is charged.
    Btw does the car crank slower on every progressive turn when started after 1 hour?
    Enviado desde mi GT-I9500 usando Tapatalk
    mdaniyal's Avatar
    May 2016
    24
    I call an electrician who checked every possible cause, that might be happening of battery discharging. But didn't find anything abnormal in generator voltage nor short-circuit. So he said that the battery is dead and need to be replace.
    Finally i go for AGS.
