Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By capricornboy2000
Thread: Best engine oil?
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Default Best engine oil?
    What would be the best engine oil for Vitz with 100k+ ODO
    I already pour Zic A, but i think its performance is not good..
    Any ideas would be appreciated
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Liqui Moly 15W-50 MOS2. Is the best oil to keep your engine healthy and also it improves the compression also so go for it.
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    Valvoline 10w40 durablend .
    Sent from my SHV-E330S using PW Forums mobile app
    Help others so that u can be Helped
    ahmed2396's Avatar
    Dec 2011
    36
    2,330
    5
    55 Post(s)
    7
    Quote Originally Posted by rajaatta View Post
    Improves compression? Can you elaborate?
    Your ego is writing cheques, your body can't cash.
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    10w 40 or 50? Seriously?
    Aren't these liquids too thick for Vitz????
    capricornboy2000's Avatar
    Sep 2015
    27
    Community Votes: 2
    So far i have read the expert opinion from this pw form. The best is 5w30 as also recommended by toyota
    FaatehRehman's Avatar
    Apr 2010
    Rawalpindi
    25
    222
    Good Answer
    Shell HX-7 5W-30. Semi-synthetic. Blue pack. Currently Rs. 2660/- for 4 litres.
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Quote Originally Posted by FaatehRehman View Post
    Thanks 😊
    Sep 2015
    27
    Dear all 100000 plus milegaed vitz k leye koi oil recommend karain. Average bht disturb hai.
    Thanks
    ahmed2396's Avatar
    Dec 2011
    36
    2,330
    5
    55 Post(s)
    7
    Best Answer
    Quote Originally Posted by capricornboy2000 View Post
    Thanks
    Shell Helix 5W30
    Sep 2015
    27
    5w30 has low viscosity which is recommended for new engines. I am already using 20w50. Plz justify the recommendation.
  12. #12
    ahmed2396's Avatar
    Dec 2011
    36
    2,330
    5
    55 Post(s)
    7
    Doesn't matter if your engine is good it will not do anything strange. You are using a very thick oil in your car which was used in cars made in 1960-70s.
    Sent from my iPhone 6s using PW Forums
  13. #13
    Apr 2010
    Rawalpindi
    25
    222
    Can you justify the 20W-50, thicker oil?
    Thicker than recommended oil is only used in cars like Vitz when your engine is consuming more than normal amount of oil. It is done to avoid rebuilding the engine's weak rings and seals.
    Your car engine is designed keeping specific oil in mind. Thicker oil will reduce fuel economy and thinner oil will seep through the seals and burn along fuel.
    And for your second question, thicker oil will give you less average.
  14. #14
    Sep 2015
    27
    My car average is low. I.e 13 in long.
    But shifting to thinner oil may lead to sudden wear and tear.
    My car is not reducing oil.
    Engine seems to be perfect. Most experienced oil sellers recimmneding 20w50. Some other pw experts like atta ur rehman bhai also recommneding the same.
  15. #15
    imrananr's Avatar
    Jun 2014
    845
    5
    19 Post(s)
    Quote Originally Posted by m_umairr View Post
    Yes too thick.
    the maximum with high mileage and oil cosumption you can use is 0W40 or 5W40.
    5W30 is for all weathers in Pakistan.
    20w50 is disaster for the engines.
    50 viscosity is used for racing cars with engine rpm touching red line or for towing.
    Don't leave a highway for a byway....
  16. #16
    imrananr's Avatar
    Jun 2014
    845
    5
    19 Post(s)
    Completely 'JAHIL' approach.
    80 percent of wear and tear of an engine takes place from starting till the engine obtains the normal operating temperature.
  17. #17
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    I am using 10w/30 for 133,000 driven vitz
    Sent from my GT-I9192 using PW Forums mobile app
  18. #18
    Sep 2015
    27
    Thanks 😊
    Quote Originally Posted by imrananr View Post
    Imrananr ap lagty hai gher sy jhagra kr k message kr rhy hain. Ye pw form hai koi parhy likhy logo wala behave karain. Agar itny hyper hain to yaha reply na karain
  19. #19
    Sep 2015
    27
    [QUOTE=faizanali;5171090]I am using 10w/30 for 133,000 driven vitz
    Sent from my GT-I9192 using [URL='https://siteowners.tapatalk.com/byo/displayAndDownloadByoApp?rid=75082']PW
    How much fuel average u r getting ??
  20. #20
    imrananr's Avatar
    Jun 2014
    845
    5
    19 Post(s)
    Did I say anything wrong? If some body says that thicker oil will give more protection to the engine parts with regards to wear and tear is utter nonsense passed on to us by footpath mechanics which we believe in blindly.
