Results 1 to 4 of 4
Thread: Whistle sound when AC on
    qasimi3882's Avatar
    Oct 2013
    30
    29
    Default Whistle sound when AC on
    When ever I turned on AC in my vitz 1000cc 2007, and then accelrate there is whistle sound.
    One more thing today I struck in thunderstorm,2 things happended
    -some water leaked on my foot (driver side)
    - battery light on and some strange sound from car front, after some time sound and light also goes off
    ahmed2396's Avatar
    Dec 2011
    36
    2,330
    5
    55 Post(s)
    7
    That shows your AC system is low on refrigerant get it topped up
    Sent from my iPhone 6s using PW Forums
    Your ego is writing cheques, your body can't cash.
    FaatehRehman's Avatar
    Apr 2010
    Rawalpindi
    25
    222
    With engine running and AC on, put some drops on water on the belt; if the whistling noise subsides then there is a problem with your belt. Either the belt is weak or tensioner needs adjustment. Mud on the belt or pulleys is also a cuase of this noise.
    You can apply grease to temporarily rectify the issue.
    If the noise does not subsides then it is probably the bearing of your AC compressor.
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Belt is loose through AC pulley, tighten it a bit and also grease it a little.. will go away..
    I had same issue.. it's resolved now!
