Page 3 of 9 FirstFirst 12345 ... LastLast
Results 41 to 60 of 168
Like Tree13Likes
Thread: Vitz long self
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Default Vitz long self
    Aoa guys
    My vitz is taking longer selfs in a random manner.. Sometimes starts on half self and sometimes it takes 2-3 seconds..
    If i press accelerator and start it starts immediately.
    Please help rectify issue
  2. #41
    imrananr's Avatar
    Jun 2014
    848
    5
    19 Post(s)
    Quote Originally Posted by faizanali View Post
    Ap to gusa hi kar gae
    App pa to nahi hans raha tha
    Why you take it wrong
    I never ever suggest to clean radiator with distaled water
    Read again complete
    Ap jo others ki bat karhe the us pa lollz kaha tha
    Sent from my GT-I9192 using PW Forums mobile app
    Brother, @spiderman-17 is not from Pakistan. He does not understand Urdu.
    Don't leave a highway for a byway....
  3. #42
    spiderman-17's Avatar
    Jun 2016
    106
    6 Post(s)
    Quote Originally Posted by m_umairr View Post
    That can give you some indication for your problem
    1) fuel starvation, it could be that the fuel pump is not delivering the fuel necessary to start the engine, when you press the acceleratior more fuel goes into the cylinder and thats why it starts
    2) bad or dirty MAP sensor, not correctly detecting the air pressure going through the throttle body, thus supplying less fuel into the cylinders. are you getting good fuel economy? (+13km/ltr in city)
    3) dirty plugs or worn out plug cables
    4)low octane in fuel. Low octane fuel detonates faster then hi octane fuel so it detonates before the piston reaches top dead centre and thats why engine vibrates on low idle (premature combustion chamber explosions) the ecu tries to compensate for these but depends of the data given to him from the knock sensor
    5)low battery cold start amperes. The engine needs a good kickstart especially when cold. If it is not getting this it will take longer to start
    Ignore 02 sensors at this stage because the ecu starts the engine at what is called open loop (it does not try to deliver a lambda value of 1.0 or 14.7:1 air/fuel ratio) because 02 sensors don't deliver data when cold, when they are hot enough (very hot) they start to deliver voltage variations to ecu, then ecu goes to close loop but it can take 2-3 minutes ecpecially with non heated sensors
    @imrananr .. Thanks!
  4. #43
    usman_arooq2's Avatar
    May 2011
    Sialkot
    1,437
    13 Post(s)
    Read again complete
    Kerosene oil won't do nothing to rust. better use soda or citric acid solution(can't remember exactly but @Xulfiqar has posted the procedure multiple times) and flush it multiple times with distilled water than add coolant mix.
    Bella, You give me everything just by REVing - NEONLIGHT SAGA: NEWTUBE
  5. #44
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Quote Originally Posted by spiderman-17 View Post
    This could be the issue, i feel fuel pump is faulty and is responsible for this behaviour. Not sure though.
    I get approximately 13 km/l in city with AC. I did clean MAP sensor myself after servicing throtle body(Not to mention, i do tuning myself other than the computer, as i don't have a scanner)
    Plugs are only 3 months old and are regularly cleaned.
    I always try to mix Hi-Octane with super fuel, but i have not been able to find it lately easily. I would like to mention here that problem arose when i poured two tanks of hi octane continously, it was okay before though.
    Battery is okay, no carbon yet. water level is okay and indications are okay too.
    For my satisfaction, i changed O2 sensor though.
    One thing I need to confirm, is there any second catalytic converter beneath the vehicle? I have heard mixed opinions about it. Some people say there is a second catalytic converter just beneath driver seat also other than the primary CC that is adjacent to Engine?
  6. #45
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    No soloution till now to your problem??
  7. #46
    Jun 2016
    106
    6 Post(s)
    There is 1 cat convertor in your car because ther is 1 bank of cylinders (cyl 1,2,3) monitored by 1 pre and 1 post Oxygen sensors, besides it doesn't make sense to put 2 cats in series on 1 exaust pipe
    Eg: A typical V6 engine will have 2 because it has 2 banks of cylinders (bank 1 will have cyl 1,2,3 whilst bank 2 will have cyl 4,5,6). It will also have 4 O2 sensors (2 on each bank) This is just an example because there are varations in v6, v8 engines.
    Hope i explained it well
  8. #47
    imrananr's Avatar
    Jun 2014
    848
    5
    19 Post(s)
    Quote Originally Posted by rajaatta View Post
    I don't think it's a problem. I thinks he's over anxious with this minor thing of long cranking to start the engine, that also occasionally. Just an opinion. No offence.
  9. #48
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    How come i hear people having two cats and breaking the second one for better performance?
    It just doesn't make sense!
    For a reference, check it out:
    https://www.pakwheels.com/forums/vit...-cat-removal-2
  10. #49
    Jun 2016
    106
    6 Post(s)
    I think u 'maybe' did not understand what he did in the link you posted
    He said (and I quote) "Removed CAT con after drivin 70k kms, and after that installed additional DHOLKI to reduce noise whhich comes after CAT"
    So he removed the catalytic converter and installed an extra engine noise suppressor (i don't know what DHOLKI is) to compensate (reduce noise) for the lack of cat. Convertor. (somthing I don't recommend)
    I am starting to beleive that pak has many mechanical engineers, but I could be wrong
  11. #50
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    He surely said that. But did you see the pictures? He never did anything in the engine bay, infact beneath the vehicle?
    "Dholki" is what we call round cylinder thing in exhaust pipe in urdu
  12. #51
    Jun 2016
    106
    6 Post(s)
    Yes, I did.
    In pic 3 with title 'Broken cat con' you can see the mix of precious metals. Platinum and others unfortunatly lying on the floor. He emptied (distroyed) his cat from under the car. (Pic 2)
  13. #52
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Yes, I did.
    So you agree there is a cat underneath?
  14. #53
    Jun 2016
    106
    6 Post(s)
    NO,
    The cat is in front of the engine in a vertical position, you can see the bottom of it in pic 2
  15. #54
    imrananr's Avatar
    Jun 2014
    848
    5
    19 Post(s)
    Umirr, DHOLKI or silencer is not cat. conv. Do not confuse CAT. With DHOLKI. They are separate; both are on the exhaust piping from engine exhaust till tail pipe.
  16. #55
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    Quote Originally Posted by imrananr View Post
    @spiderman-17, I would like to say sorry for this poor attitude of @faizanali. We Pakistanis are very poor in listening to others and justifying our point with logic.
    The thing Spider linked with me its never ever recommend by me actuly
    Any ways be happy and relax every one 😊
  17. #56
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Have you got your problem resolved?
    Do share if problem is resolved
  18. #57
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    In modern jdm vehicle's 2 or 3 cats in row are common due to strict emission checks. The efficiency of the primary cat is monitored only via a post cat sensor.
  19. #58
    imrananr's Avatar
    Jun 2014
    848
    5
    19 Post(s)
    Any ways be happy and relax every one 
    Some times it's difficult to crack a 'NUT'.
  20. #59
    Jun 2016
    106
    6 Post(s)
    Agree 100%, I saw some in my country (2 in line) but the engine was > 1500cc, never saw a sub 1000cc with 2 cats inline. I saw a sub 1000cc Euro 6 but it was with one (but a bit longer then the vitz
  21. #60
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Quote Originally Posted by walls View Post
    Not yet brother.. Still figuring out the issues
