Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 168
Like Tree13Likes
Thread: Vitz long self
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Default Vitz long self
    Aoa guys
    My vitz is taking longer selfs in a random manner.. Sometimes starts on half self and sometimes it takes 2-3 seconds..
    If i press accelerator and start it starts immediately.
    Please help rectify issue
  2. #61
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Quote Originally Posted by rajaatta View Post
    In modern jdm vehicle's 2 or 3 cats in row are common due to strict emission checks. The efficiency of the primary cat is monitored only via a post cat sensor.
    I suspect vitz late 2nd gen has a 2 stage catalytic converter.. Just need to confirm it it is the case
  3. #62
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Quote Originally Posted by imrananr View Post
    Umirr, DHOLKI or silencer is not cat. conv. Do not confuse CAT. With DHOLKI. They are separate; both are on the exhaust piping from engine exhaust till tail pipe.
    Imran i do und that not every dholki contains cat.
    Did you check our the pw posts i referenced to spider? I suspect vitz has a 2 stage cat converter.. One of the toyota guy confirmed it to me.. Though he isn't with toyota anymore.
  4. #63
    fahad4434.ali's Avatar
    Aug 2016
    19
    41
    I am also facing the same issue in my Vitz, only 15k kms genuinely driven its a 2015 manufactured, previously it was perfect, i used pure hobc many times but the very last time when I got my oil changed and poured in hobc, my car started to taking longer time spans to start like 3-4 seconds. Maybe because I also washed the engine with water. And also can it be a battery issue because once someone left the light inside the car turned on for a day.
    Sent from my SM-G935F using PW Forums mobile app
  5. #64
    imrananr's Avatar
    Jun 2014
    837
    5
    19 Post(s)
    Quote Originally Posted by fahad4434.ali View Post
    Use 60/40 ratio HOBC and supreme and your issue will be resolved. But, don't worry if it takes long self (single self) to start. I would still prefer pure 100% HOBC over mixed ones.
    Don't leave a highway for a byway....
  6. #65
    imrananr's Avatar
    Jun 2014
    837
    5
    19 Post(s)
  7. #66
    imrananr's Avatar
    Jun 2014
    837
    5
    19 Post(s)
    Quote Originally Posted by m_umairr View Post
    Vitz has one CAT as far as I know. It's only 1000cc (3-cylinders) mostly in Pak.
  8. #67
    kkoool's Avatar
    Apr 2005
    35
    1,661
    I dont know why people opt for HOBC when your car is designed for Super 87 Ron Etc. Most of the HOBC is just leaded Super
    Say good bye to your catalysts and valves earlier than their time period.
    I have personally experienced a choked catalyst on Reborn 2008 at 60,000km due to constant use of HOBC and another reborn has ran over 120,000km on Regular fuel without any choked CAT.
    If your having knocking issues, use proper Fuel from a good petrol pump not just any that you find on road. Use proper oil, recommended spark plugs only
    AE 86
  9. #68
    imrananr's Avatar
    Jun 2014
    837
    5
    19 Post(s)
    Quote Originally Posted by kkoool View Post
    Well, the minimum octane fuel rating for JDM vehicles is 90+. Since we see new vehicles with higher compression ratios, 10.5:1 and above, RON 87 is too less for that matter. HOBC sold in Pakistan is around RON 91, perfect for imported vehicles with high compression ratio engines.
    Higher octane rated fuel has nothing to do with choking of CAT and valves.
  10. #69
    kkoool's Avatar
    Apr 2005
    35
    1,661
    The first sign of sticking valves is experienced during morning when the engine is cold and valve clearances are less, keep on blending the 60:40 50:50 30:70 ratios and ruin your CAT and valves, first try to get the Lead out of HOBC or you have a perfect recipe of deposits around valves due to increased temp in combustion chamber.
    "aagay aap ki marzi bhai"
    What I am trying to say is that HOBC in Pakistan is not mostly HOBC, so beware, the pumps / refineries here are experts in adding other things in fuel as well.
    AE 86
  11. #70
    rkbladex's Avatar
    Nov 2014
    189
    6 Post(s)
    I think the Problem is related to fuel so you need to check the whole fuel system like Restricted in tank Fuel filter, Fuel Pump, Fuel Pressure Regulator, clogged Fuel line if any so i am also facing this issue so my opinion is the problem is fuel pressure. So i read on internet EFI cars runs on high fuel pressure i don't know how much it is correct.
    - RKBladeX
    If you found my response helpful!!. Don't forget to press like button
  12. #71
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Quote Originally Posted by rkbladex View Post
    - RKBladeX
    If this was the case, why 2 fuel pumps burned out? I recently changed fuel filter and fuel pump but it is of no use at all..
    I am unable to trace out issue
    as a progress note, i opened my o2 sensor(exhaust pipe one) and cleaned it with nasa oxygen sensor cleaner i feel long selfs are now history.. But need to confirm for a day or two for confirmation..
  13. #72
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    - RKBladeX
  14. #73
    spiderman-17's Avatar
    Jun 2016
    106
    6 Post(s)
    I doubt you will solve long selfs by cleaning an O2 sensor only, because:
    1) o2's are not used during igniton in a vitz, (already explained this in a previous post in this thread)
    2) you never actually clean an o2 sensor because the sensor is encapsulated in a metal shield to protect the sensor itself from carbon etc. So you cleaned the sensor protection shield. This shield can be dirty and the sensor still reads correct oxygen because oxygen is a gas not a Liquid. If this sensor was a thermostat (sensing liquid, then cleaning will improve the reading). O2's (like everything) have a lifespan, when it expires, you replace it
    On the bright side, you could have found an air leak, which you fixed by re tightening the o2
  15. #74
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Quote Originally Posted by spiderman-17 View Post
    Very informative spider👍 thanks a lot 😊
  16. #75
    Aug 2016
    19
    41
    Surprisingly after I topped the car with unleaded fuel yesterday and started it today morning it started within a second compared to hobc which took 2-3 seconds, so I guess pure hobc is not a good choice. Is 60:40 fine? Hobc:super.
  17. #76
    walls's Avatar
    Feb 2010
    30
    213
    2 Post(s)
    Where is this o2 located?
    It can be done d.i.y ?
    Sent from my GT-I9192 using PW Forums mobile app
  18. #77
    Jun 2016
    106
    6 Post(s)
    Quote Originally Posted by walls View Post
    There are 2, one before the catalytic converter and one after
    For the DIY, it depends what you want to do. BUT, as the old saying says, if it's not broken don't fix it.
  19. #78
    DUDE007's Avatar
    Oct 2011
    2,033
    104 Post(s)
    Did you do any changes to your car before shifting from 87 RON to 98(correct if wrong)? i wonder why people here face issues running HOBC in vitz.
    Enviado desde mi GT-I9500 usando Tapatalk
  20. #79
    Jun 2016
    106
    6 Post(s)
    Quote Originally Posted by DUDE007 View Post
    I shifted from what was in the car when i got it from japan to 1 tank of ron 95 and then always used 98. I Didn't do any thing to the car, even though there is only 3% increase in RON, i got a clean/smoother ride and some 1.75 kms increase in milage
    I don't know what's in HOBC in Pakistan (and would like to know) but the vitz is made, and programmed to run on unleaded fuel, thus leaded fuel is harmful to the engine especially valves
  21. #80
    walls's Avatar
    Feb 2010
    30
    213
    2 Post(s)
    Actuly my car also take long self.. but not regularly
    Once in a week
    May be my car o2 sensor also need to be clean
    Thats why asking
