Results 1 to 12 of 12
Thread: Toyota Vitz 2003 Fuel Pump
    ali.iqbal2040's Avatar
    Sep 2016
    6
    Default Toyota Vitz 2003 Fuel Pump
    Hi, good afternoon everyone.
    I have Toyota vitz 2003 model, import in 2007. The car has fuel pump issue. I have so many times changed it with used fuel pumps available in market. But after working 2 months it got expired. Please suggest should I use new fuel pump for it or is there any other problem. Also let me know price for the new and which is the best place to buy it.
    Thanks
    m_umairr's Avatar
    Sep 2011
    168
    2 Post(s)
    5
    Bump
    Sep 2016
    6
    Hi everyone, waiting for the right answer!
    shehzadakbar12's Avatar
    Sep 2016
    7
    Change the fuel filter assembly along with the pump. I suggest to install new and genuine fuel filter assembly and pump.
    rkbladex's Avatar
    Nov 2014
    189
    6 Post(s)
    You can find genuine fuel filter and Fuel Pump part no from below website for your reference.
    Please make sure you select the correct car model and year and its variant.
    VITZ / toyota | model list?JP-CarParts.com
    - RKBladeX
    If you found my response helpful!!. Don't forget to press like button
    sirdneo's Avatar
    May 2013
    84
    4 Post(s)
    Quote Originally Posted by ali.iqbal2040 View Post
    Thanks
    I also have Vitz 2003 model and my fuel pump was dead, my mechanic replaced it with Orignal GLI Fuel Pump, dono hight main thora sa difference tha liken width dono ki braber thee. It has been around 3 years it is working absolutely fine.
    Old/used pumps kisi kaam ky nhe hoty bar bar kholny aur band kerny sy gari ki baj jati hy, always install brand new and genuine parts in your car.
    If you live in islambad I can give you the number of mechanic.
    Sep 2016
    6
    Hi, thanks for your reply. I have checked from toyota service center, they don't have vitz fuel pump. And GLI fuel pump priced at PKR 55000. Plz tell me any cheap solution.
    Sep 2016
    6
    Did you use GLI new fuel pump or used, and what was it's cost?
    sirdneo's Avatar
    May 2013
    84
    4 Post(s)
    It costed around 4~5K and it was brand new
    Sep 2016
    6
    Hi yeah plz give me your mechanic contact number. Brand new fuel pump only at 4k-5k. Is it Chinese manufacturer or original from toyota. If it is Chinese plz let me know it's company and where from you buy it?
    Thanks
    sirdneo's Avatar
    May 2013
    84
    4 Post(s)
    03455955150, his name is ali and his shop is near zarie traqiyati bank G7. Fuel pump was XLI/GLI Orignal i think
  12. #12
    Sep 2016
    6
    Thanks very much I will contact him.
