Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By spiderman-17
Thread: Vitz 2008 brakes getting hard with AC on
    haseebhamid's Avatar
    Feb 2009
    Rawalpindi
    31
    23
    Default Vitz 2008 brakes getting hard with AC on
    Hi,
    Today as I was coming back from office I felt that my brakes are not working on low rpms and AC on. After 30 min of drive check engine sign also appeared on the meter. With AC turned off there is no issue with brakes. For the last few days I was getting a whistle like sound but very low from the AC blower but I ignored it as it was very minute. Anyone having a clue how could an AC and brakes be linked? Advise pls.
    Sent from my HTC One_M8 using PW Forums mobile app
    Similar Threads:
    lahori's Avatar
    Apr 2005
    36
    1,013
    26 Post(s)
    Quote Originally Posted by haseebhamid View Post
    Hi,
    Same is the case with my Cultus
    If travelling was free, You'd never see me again.
    spiderman-17's Avatar
    Jun 2016
    106
    6 Post(s)
    Hi,
    A car's AC work on DC current, and so do Brakes (abs sensors, etc. )....
    If (as you said) you have a fault light in the dashboard, then get your car scanned as soon as possible, don't play games with brakes if you care for your life and that of others
    Feb 2009
    Rawalpindi
    31
    23
    Got it checked today with the mechanic and he told its an issue related to the butterfly that. You better get it repaired or better buy a full kabli throttle body.
    Will replace the throttle body in next coming days
    speedster_101's Avatar
    Sep 2005
    3,447
    54 Post(s)
    Throttle body must be expensive.
    It's always good to go for second opinion.
    "The more we sweat in peace, the less we bleed in war"
    shadab_lodhi's Avatar
    Feb 2012
    Rawalpindi
    85
    Check for vacuum leaks around the intake manifold. More over do the throttle body cleaning and re-learning.
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    check the engine compression of the car it usually happens after low compression as the vacuum get weak after it
    Ae110 /G100
    Feb 2009
    Rawalpindi
    31
    23
    What does the error code p0016 crankshaft position - camshaft position
    Corelation bank 1 sensor A
    Means, anyone?
    Sent from my HTC One_M8 using Tapatalk
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
