Results 1 to 20 of 20
Thread: Knocking sound
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Default Knocking sound
    Asalam o Alekum
    A new sound of knocking appears in my vitz 2nd generation with 1 kr 1000cc engine
    Sound starts obove 30 kmph speed as gear is shifted to bigger one.. (Auto Transmission) sound is like driving slow on higher gears.
    But it is disappeared if I accelerate more or reduce the acceleration.
    There is no knocking sound if I drive car on S gear.
    I have tried mixture of hobc or 100% hobc but no effect.
    Kindly guide me what should I check.
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Quote Originally Posted by walls View Post
    Asalam o Alekum
    W/salam.
    Time to change the oxyhen sensor with a brand new one. And also get the intake manifold and intake ports serviced and you are good to go. Don't waste your time on hit and try methods thats your only solution.
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Oh thats the reason
    Few days back I notice smell from silencer like un burn fuel..
    It was also related to this problem?
    And what it will cost?
    Servicing the sensor may resolve the problem?
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    But there is no engine check light indication so far..
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    I removed the top sensor and bottom sensor switch out.. no check engine light appear.. car drive was so powerful but with same knocking..
    Then I switched both sensor again.. Knocking sound is reduced. Not disappear yet.. will get it checked from some good mechanics for sensor replace or service
    spiderman-17's Avatar
    Jun 2016
    106
    6 Post(s)
    Hi,
    Does both of your top and bottom o2 sensors have 3 wires?
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Top sensor having 4 wires and bottom sensor switch having 2 wires
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Update.
    Today O2 sensor checked through meter and found ok.
    Jun 2016
    106
    6 Post(s)
    Update.
    What were the readings? Were they flactuting between 0.1v to 0.9v? If so, it was correct
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Cold engine reading
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    On car start reading was increased about 86
    And on car engine switched off reading was near 42.
    Sent from my GT-I9192 using PW Forums mobile app
  12. #12
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    I have also made video of this checking process.. but video upload nahi ho pa rahi
  13. #13
    Jun 2016
    106
    6 Post(s)
    What are 86 and 42 ?
    To know if an o2 is doing its job correcly (because it is a crucial sensor for the engine performance) you should connect it to an obd scanner
    A good pre cat o2 should vary fast between 0.1v and 0.9v whilst driving in normal conditions
  14. #14
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Readings were like this as shown in picture
    I will get it scanned on Monday
    Reading on obd scanner must be as you have mentioned?
  15. #15
    Jun 2016
    106
    6 Post(s)
    Yes, vary the engine RPM between idle and 2500rpm simulating like driving the car normally
    The post cat o2 shold be stable between 0.4v and 0.9v indicating the cat is working correcly,
    If it varies up and down like the pre cat, that means the cat is not doing its job
    Engine must be hot or you wont get any readings from post cat o2 because it is not heated (2 wire)
  16. #16
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Quote Originally Posted by spiderman-17 View Post
    The post cat o2 shold be stable between 0.4v and 0.7v indicating the cat is working correcly,
    Ok
    Will update the readings after obd scan. O2 sensor also shows catlytic convertor performance?
  17. #17
    Jun 2016
    106
    6 Post(s)
    Ok
    Sure, thats why there is the post cat o2 in your car, if both the o2 sensors read the same reading (both going up and down) , that means the cat is doing nothing
    Also the cat needs to be very hot to do its job, that why it has a metal cover around him (to keep it very hot)
    If the catalytic converter is functioning correctly there will be very few oxygen content in the exaust as carbon monoxide and carbon dioxide is catalyzed in the converter.
  18. #18
    DUDE007's Avatar
    Oct 2011
    2,034
    104 Post(s)
    @spiderman-17 is there an EGR valve in vitz? Can you please share it's exact location and also the location of PCV valve. I want to clean them.
    Enviado desde mi GT-I9500 usando Tapatalk
  19. #19
    Jun 2016
    106
    6 Post(s)
    Ok
    @walls I Did a small video of what can be monitored (did not include abs and airbags data) while driving a vitz 2009 this morning, note how o2 works when engine is not in optimal temperature, but unfortunately i found a lot of traffic so the throttle was most of the time 0%
    The screens are transmitted wirelessly to a pioneer head unit from my android mobile phone,
    https://drive.google.com/file/d/0BxD...w?usp=drivesdk
    @DUDE007
    Yes it has both but i dont have the car at the moment so cannot send you pics
    The egr works if the car meet a specific condition, you can see it in video above
    The pcv is the first thing to clean if your engine is consuming too much oil before you do compression tests etc.
  20. #20
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    @DUDE007
    That's very informative video.
    Thanks for sharing.
