Results 1 to 8 of 8
Like Tree3Likes
  • 1 Post By rajaatta
  • 1 Post By Thinking
Thread: Engine oil for break in period of cars
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Default Engine oil for break in period of cars
    Aoa I am planning to rebuild 1krfe of my 2nd gen vitz , I read somewhere that for break in period I should pour mineral oil such as 10-40 , is that correct
    Normally I use 5-40 fully synthetic shell imported oil in the same engine
    Is this grade fit for 1krfe or shall I switch to 5-30 ?
    @Xulfiqar , if u could please help me for choosing engine oil for break in period
    Sent from my ALE-L21 using PW Forums mobile app
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Any one ?
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    What makes you think your engine needs overhualing?
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Replacing engine rings , and doing head only ! Engine rings have worn out
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Quote Originally Posted by salmanrasheedpsh View Post
    Ok for rebuild you need few of the things.
    If you are lucky enough to find liqui moli shop in peshawar. Than buy following products.
    1: 10W-40 MOS2.
    2: Ceratec 1can
    3: Motor Protect 1can.
    4: Motor Oil saver 1can.
    Pour the engine oil and add all 3 cans in it remember level up the engine oil 3.6 liters and add these treatments ober into the oil.
    Oil filter check after first 2000 kms.
    Inspect the oil filter after 2k s and replace it. Than you are good to go for 5 k more.
    Remember to break in the engine in cvt transmission you had to struggle more than a normal transmission vehicle.
    Will describe the procedure after wards. Good luck
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Quote Originally Posted by rajaatta View Post
    1: 10W-40 MOS2.
    2: Ceratec 1can
    No liqui moly dealer in Peshawar will have to source it from isb ,
    Is it OK to pour createc etc in a newly built engine ?
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Yes it is it will help in more reduction in friction.
    Thinking's Avatar
    Jul 2008
    34
    2,306
    62 Post(s)
    shell helix ultra 5w-40 would do the job quite appropriately. you can keep using it.
    or you can also shift to toyota taglon 5w-50.
