Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By walls
Thread: Vitz 1krf cold Start sounds
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Default Vitz 1krf cold Start sounds
    Asalsm o Alekum
    In morning when I start my cold car. Its RPM remain a bit higher and a sound like tappet loose.. khrr khrr type appears.
    As car get warm the RPM gets normal and tappet sounds disappeared.
    Is this normal in cold start??
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    No reply
    Mean its normal 😂
    Sent from my GT-I9192 using PW Forums mobile app
    humayun.chughtai.7's Avatar
    Nov 2013
    Multan
    20
    623
    9 Post(s)
    Dont worry. Its totally normal bcz my vitz also does the same.
    Sent from my SHV-E270L using PW Forums mobile app
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Quote Originally Posted by humayun.chughtai.7 View Post
    Thanks for reply and information.
    engineer6's Avatar
    Dec 2010
    Peshawar
    14
    I am using vitz 2001 and experience amost the same issue. People advised me to use high octane and injector cleaners but nothing helped me much.
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Its 5 mints high rpm then all good to go na??
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    High rpm on cold start are absolutely normal and so is slight tappet noise
    walls's Avatar
    Feb 2010
    30
    215
    2 Post(s)
    Yes I observed some other cars too
    Thats normal for efi system to get optimize temperature on cold start
