Salam members !
Recently I bought a toyota echo 2001v(same as vitz) london model. It has 2nz engine under the hood with AT tranny.
Now here I need ur help. 3 days ago I noticed a weird problem in my car. Sometimes (after driving) when I turn the key to ACC to turn off the engine, everything turns off including meter lights, blower etc but the engine won't and when I move the key from ACC to lock position, the self-starter kicks in during the already running engine due to which a huge karrrr karrr sound is produced.
Then I went to electrician, he found that the wiring of ignition switch is tempered. Khair he satisfied me by saying that k mene ab sari wiring set krdi hai, ab masla nhi hoga. Next morning, again same problem.
Weird thing is that when this issue happens, heat indication light turns on in the meter. And some times engine check light also comes on while driving but then it goes off after 2-3 hours.
I am thinking to get the ignition switch replaced with kabuli one.
Experts what is your take on this issue ? Plz help me sort out this problem. I am really worried about it. @xulfiqar and other experts.
Sent from my SHV-E270L using PW Forums mobile app
