Results 1 to 14 of 14
Thread: vitz help required
    Missing_in_Action's Avatar
    Aug 2006
    36
    104
    Default vitz help required
    @all the experts of vitz
    please tell me the specs of the following to be used in 2002 vitz
    Transmission oil (ok i know its supposed to be T-IV type)
    Engine oil
    Power steering oil
    Brake Fluid / Oil
    Radiator coolant
    any other oil/filter that needs to be changed other than air filter and oil filter?
    i've searched the forums but couldnt find the relevant info
    thanx in advance
    woof! woof!
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    I remember seeing a similar post somewhere maybe u can do a search on Vitz.
    AkbarGr8's Avatar
    Oct 2004
    32
    5,972
    8 Post(s)
    MIA, get in touch with Storm, he shall guide you thoroughly since he's been through this phase
    Bees waal 4 life
    Aug 2006
    36
    104
    @AkbarGr8 & @ tyrone_40
    thanx for ur replies. i guess i'll have to talk to sameer bhai then
    woof! woof!
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    from toyota capitol ISB
    Transmission oil - Type TIV - 1380Rs
    Engine oil - TMO 2000 (4 litres) - 700Rs
    Air Filter - 1250Rs
    Brake Fluid/oil - 345Rs
    Brake Fluid/oil change (labour) -100Rs
    Brake Service Labour - 500Rs
    Engine Oil & Filter Labour - 100Rs
    Engine Tune-up (Fuel & Air Filter) Labour - 500Rs
    Fuel Filter - 2100Rs
    General Checkup Labour - 300Rs
    Oil Filter - 450Rs
    Power steering oil & Transmission oil Labour - 300Rs
    Radiator (LL Coolant) - 890Rs
    Service Sundries 34+2 - 36Rs
    pending from toyotal capitol ISB
    Timing Bearing
    Timing bet
    V-Belts
    Wheel Bearing Greasing
    Once you've gotten all of this done you shoudl be more than happy with the way your car drives. I would suggest you take some time out and get your intake manifold cleaned and have your shocks changed (do not get this work or parts from toyota - i can tell you about alot of sources for Vitz parts at a fraction of the cost).
    Also as hash4u once poiinted out you should also get your catalytic converter checked because they fail with leaded fuel and will lead to them becoming choked and killing the performance of the car.
    Aug 2006
    36
    104
    Sameer bhai thanx for ur help
    i'm going to toyota ppl on next weekend for all this maintenance
    woof! woof!
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    @MIA
    just make sure you book in advance or they'll make your life miserable. I am a personal friend of the awan family and once i went there with nashit/guncha and i waited for 3 hours only to find out that they hadn't even started working on my car.......
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    @Storm
    Will all this maintenance and purchase of oils and parts etc. be cheaper if not done from Toyota and purchased from places like say, Plaza area in Karachi? I was just wondering?
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    @tyrone
    indeed it woudl be cheaper to buy the oils (and other parts) from an independant supplier. I just paid the little bit extra for the convenience, luckily i kept track of the costs and shared them here. at least now people can caompare "company" prices with 3rd party prices and look for better deals.
    I always advise people to shop around for such items if they have the time as there is alot of money to be saved by doing this.
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Thanks for the reply @Storm. I guess we usually dont want to take the time out to shop around and prefer to spend a little extra money to get the parts the easy way. I went a number of times to Shershah and you won't believe the stuff u get there.
    Was Toyota importing these parts before anyone else when the Vitz and other cars came into the market?
    RedBull_ar's Avatar
    Jun 2005
    Tank
    30
    6,722
    a friend has a vitz
    this is wt we,ve done so far
    from liqui moly/cofron dealer/workshop
    Transmission oil ...........................??
    Engine oil - (4 litres) synthetic.....1800Rs
    Air Filter -......................................was fine
    Brake Fluid/oil ........dot 4..............??
    Brake pads (pair)...........................2000rs
    Engine Oil Filter............................ 350Rs
    Fuel Filter .................................... 2500Rs
    Radiator (LL Coolant) ...................??
    pending
    spark plugs
    tune up
    result
    car drives smooth, pick not as much as i expected
    @storm
    do u have any manual in english
    howz the pic with 4 ppl?
    @mia
    brake oil dot 3
    engine oil S/J atleast
    Alpha Romeo 156
  12. #12
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    @tyrone
    toyota only started to support the vitz when they realised that they were missing an oppertunity to make alot of money. I had no choice as i had to get the car up and running in 1 day as my wife needed the car ASAP.
    @redbull
    pick is good when compared to other 1.0 cars in it's league but even with 1 person it's no performance car. as a general rule of thumb with all of these econocars i'd say each passenger added will subtract 1-2 seconds off it's 0-60 time.
  13. #13
    nhamid's Avatar
    Jul 2005
    43
    Are parts easily available in market now, especially in Lahore? I was interested to buy vitz but mechanics warned me not to buy only because of the unavailability of it's parts. More detail is highly appreciated. Thanx
  14. #14
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Same here. Mechanics tend to be against this car. I dont know why. Mine also says the same thing but I am going to go for it as soon as I sell my car.
    My electrcian was saying the reason is that they will lose their customers as this is an EFI car and not much for them to do.
    Is that true?
