Page 1 of 3 123 LastLast
Results 1 to 20 of 57
Thread: Two problems in Vitz.
    smartkhan's Avatar
    Feb 2006
    36
    310
    Default Two problems in Vitz.
    Dear brothers,
    I am facing two problems in my Vitz 2000.
    1. The digital meter is showing "O/D OFF" sign. What's that?
    2. Sometimes meter shows "Check Engine" sign and sometimes it does'nt.
    I've changed the engine oil and also checked all other fluids. Everything is fine.
    Vitz owners please help me out. Thanx in advance.
    Best Regards,
    Hassan Khan.
    If you can count your money, you don't have a billion dollars.
    Every country has an Army. Pakistani Army has a country.
    smartkhan's Avatar
    Feb 2006
    36
    310
    Vitz owners? Are you all alive?
    Lonely_Puma's Avatar
    Oct 2006
    37
    55
    1. O/D OFF indicates 'Over drive' is off. Which means that your car would not be going into fourth gear, only upto the 3rd. This provision is there for city or mountainous driving when you purposely do not want to shift to the 4th gear. How to turn O/D on, notice there should be small button below the larger shift button on the right hand side of your car's gear changer. It should be un-pressed. So if you press it (you should hear a click sound when it is pressed), then O/D should turn on.
    2. There can be different reasons for this. Sometimes it is the catalytic converter, which can be clogged or mal-functioning because of dirty petrol. My suggestion is to get your engine checked by a reputable workshop. For first time you can get it checked by Toyota.
    Hope this helps.
    This is as much of a test for me as it's for them
    robin's Avatar
    Jun 2005
    2,825
    1. u can s/w on Over drive, u may see O/D button on right side of gear lever
    2. better go for an OBD test.
    smartkhan's Avatar
    Feb 2006
    36
    310
    @Lonely_Puma
    @robin
    Thank you for the help.
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    @smartkhan
    What happened about your OBD test for the check engine light?
    smartkhan's Avatar
    Feb 2006
    36
    310
    @tyrone_40
    I dont know what O/D is. My car's digital meter is showing a light "O/D OFF". That is why i posted this problem here to ask you guys.
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    @smartkhan
    I'm enquiring about your "Check engine" light problem. Did you manage to solve it?
    smartkhan's Avatar
    Feb 2006
    36
    310
    tyrone_40
    No. I was thinking that it might be because of old engine oil. So I changed the oil and checked all other fluids. The light is still there. Sometimes it comes sometimes it does'nt. It comes when I drive more than 5-10 KM. May be engine is getting hot.
    How can we see in the meter of Vitz that engine is getting hot.
    LOGAS's Avatar
    Dec 2006
    57
    1,921
    @Smartkhan............
    Contact me if you need a solution for check engine light...
    Economy With Security And Durability.
    smartkhan's Avatar
    Feb 2006
    36
    310
    @all
    I am still having the "O/D OFF" light on my car's meter. Please help me solving this problem. I tried to press the small button but its not coming out.
    Any guys there for the solution?
  12. #12
    robin's Avatar
    Jun 2005
    2,825
    in some cars (old models) O/D button is like on/off switch but new cars always start with O/D on, u need to press it once to s/w it off, and it'd remain like this till u s/w off the engine
  13. #13
    smartkhan's Avatar
    Feb 2006
    36
    310
    @robin
    Thanx for info. I cannot press the button from my fingers as it is too thin and small. I tried to push it from KEY of car but useless
  14. #14
    baqai's Avatar
    Apr 2004
    39
    2,555
    47 Post(s)
    errr which button are you trying to press
    about check engine light i am having the same problem lately ... the light comes and goes with its own mood one change in drive i can notice is that it feels i am stuck to 2 gears when check engine light is on ...
    Lost in /dev/null
  15. #15
    smartkhan's Avatar
    Feb 2006
    36
    310
    @baqai
    There is a small red button at the top right of gear lever. Am I right?
  16. #16
    sfarhanuddin's Avatar
    Apr 2005
    36
    355
    bhai oil filter bhi change kar kay dhekhooo
    meri gari main oil filter clog ho gaya tha jis ki waja say
    engin sees ho gaya
    mainay engine oil switch change karaya phir bhi light aagi rahi aur next day engine sees then mechanic say
    always use branded oil and change filter
    thanks
    Hajj Mubarak
  17. #17
    RedBull_ar's Avatar
    Jun 2005
    Tank
    30
    6,722
    are u pressing the button the base of center console? that one is used to pull the car out of Park to N or so without key.
    the button on the right of the gear knob should be easily pressable. the light goes off when OD is ON, and turns on when OD is OFF
    Alpha Romeo 156
  18. #18
    smartkhan's Avatar
    Feb 2006
    36
    310
    @sfarhanuddin
    I have changed the oil filter.
    @RedBull_ar
    Are you talking about the button which is on the gear stick or is it near the gear stick?
  19. #19
    RedBull_ar's Avatar
    Jun 2005
    Tank
    30
    6,722
    ON the gear stick is i think OD on/off button.
    Alpha Romeo 156
  20. #20
    smartkhan's Avatar
    Feb 2006
    36
    310
    @RedBull_ar
    Thanx. I'll try to use that today. I hope it'll solve my problem.
